E-100 Ir550
  • vandezo
    I don't know
    • 161
    E-100 Ir550
    Help.....
    E-100 on IR550/600
    LD1?
    LD2?
    BD?
    how i can fix it?
    thanks 4 help
    • 23010
    Foldback Shutter
    The foldback shutter for the laser does not open wide enough, because A) the front door fits poorly, hits the fuser drawer, & pops open by itself, or B) the front door does not close properly because the control panel is deformed downward. The shutter, at the right of the laser is operated by linkage to the doorswitch. A) Install washers between magnet plate/interlock and the plastic door (3 washers). B) Remove & reform control panel metal plates, carefully. They are surprisingly soft.
    • roygunawan
      • 12
      change laser driver-2
      try to change laser driver-2.
