canon 4050 error code e020
  • a-z copies
    • Aug 2025
    Machine won't turn on, keeps saying to turn off and back on. Help!
  • century
    • 95
    E020 - The toner is not adding correctly into the developing assembly.
      • 23010
      E020
      1) If toner hopper is overfull, the toner motor worm gear splits as a result of the hopper becoming packed tight. 2) If the hopper is 1/2 full or less, the worm gear splits under normal use.
      1) Advise customer to add toner only when the toner light is lit, right away, and replace toner motor, or 2) Just replace toner motor (FH7-1762-030).
      After verifying that the toner hopper is working properly, check that the web solenoid is activating. Clean the web solenoid and ensure free action. This has been known to clear an E020.
      After verifying that all is well with the toner hopper unit, consider the DC controller. It has been noted that some DC controllers do not provide sufficient current to drive the hopper motor. Replace the DC controller COL97.08.25 M0000244.txt.
      • a-z copies
        Thanks, Blackcat
        I'll check out Monday and post results .
        • a-z copies
          canon 4050 error code E020
          Blackcat,
          You are right the toner motor worm gear was broken, changed motor and error code is still lit.
            • 23010
            Wow, am I rusty. Let's see if I can remember most of this:
            Open the front door & key the front door switch (so the machine thinks the door is closed). Use something like an allen wrench to reach through a small hole to press a switch in the upper front cover near the mechanical counter. A dollar sign will appear on the screen.
            This is where it getts fuzzy:
            I think if you press '4' you will get to the function menu. If you find the right keys you can browse to it (I think it's the *). Then Start. Then browse to Error Reset, then Start. Reset will escape you from service mode.
            Sorry I can't remember more. Hey, are there any old timers that remember this service mode?
            • a-z copies
              blackcat,there is no hole next to the mech. counter.
                • 23010
                Sorry. Somewhere in that purple inner cover there is a ~2mm hole with the service switch inside.
                I remember some more. Once in service mode press *4* use light/darker keys to browse to Error. * to execute. Power Off/On to exit. I'll keep looking/thinking.
                • a-z copies
                  Blackcat,
                  I may have to find a service manual for this Dinosaur, still trying to fine service switch on this beast, will keep looking. Thanks.
                  • lkrsardis
                    • Dec 2007
                    • 316
                    np 4050 blues
                    hey man. lucky you. you will probably need to empty and vac. the toner hopper. the service sw is just left. of the green fuser knob. also remove the dev. unit and see if the customer didnt run it dry if so go to service mode then to (4) install toner. its in the book. also pull the sensors out of the toner hopper and dev unit leave them hooked up if the are working you will hear a very high pitched sound. good luck. 4050 you got to love em.
                    Like the United States Postal Service It's a miracle it works!
                    • a-z copies
                      THANKS , Got it working!
                      Merry Christmas and Happy Holidays to all that took the time to reply.
                      • Canuck
                        Tech Specialist
                        • 1713
                        you hit the nail on the head...been this route before..6050 also..wiper spring for toner sensor..brings back memories
