ir c2020i cutting on ADF
  • sudani19
    • Jun 2009
    • 27
    Hi every one here , i installed anew ir c2020i today , every thing working probably , but when using ADF with letter size paper the copy is not complete it seems as you make amargin ,about ten cm not copied .
    when using glass the copy is accurate
    any help pleeeeeeeeeeeez
    thanks
  • teckat
    • 16083
    (test mode>"2"scan test>"3"sheet pos adj)
    • sudani19
      • Jun 2009
      • 27
      Thanx teckat
      iwill follow these & feed u back
      • sudani19
        • Jun 2009
        • 27
        sorry teckat , itried to perform service mode but icouldont enter, ist diferrent from normal procedure ( *2,8,*)
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5015
          *28* and nothing else.
          Dude,tell my the secret.Do you have IR advance series c2020?
          • sudani19
            • Jun 2009
            • 27
            yes its IR advaance series c2020i
            • teckat
              • 16083
              sorry , posted wrong info, thought u said iR2020
              • teckat
                • 16083
                IRADC2020
                COPIER > ADJUST > ADJ-XY
                ADJ-Y-DF Adj img pstn in DADF mode:horz scan[Frt]
                To adjust the image reading start position in horizontal scanning direction at DADF reading.
                When replacing the CCD Unit/clearing the RAM data of the Reader Unit, enter the value of service label.
                As the value is incremented by 1, the image position moves to the rear side by 0.1mm.
                COPIER > FUNCTION > INSTALL
                STRD-POS Scan position auto adj in DADF mode
                Details To adjust the DADF scanning position automatically.
                At DADF installation/un-installation
                Adj/set/operate method
                1) Set a paper for stream reading position adjustment, and then
                close the DADF.
                2) Select the item, and then press OK key.
                The operation automatically stops after the adjustment.
                3) Write the value displayed by COPIER>ADJUST>ADJ-XY>STRDPOS
                in the service label
                STRD-POS Adj read pstn in DADF mode: front side
                To adjust the reading position at DADF reading (front side).
                Default value 100-Display/adj/set range 1 to 200
                1) Enter the setting value, and then press OK key.
                2) Turn OFF/ON the main power switch
                COPIER > OPTION > FNC-SW
                MODEL-SZ Fixed magnifictn & DADF orgnl dtct size
                Details To set the fixed magnification ratio display and the original detection size with DADF.
                It is set automatically at the time of installation of the Reader according to the location.
                Use case Upon user’s request
                2) Turn OFF/ON the main power switch.
                Display/adj/set range 0 to 3
                0: AB configuration (6R5E) for Japan,
                1: Inch configuration (5R4E) for North/Middle/South America,
                2: A configuration (3R3E) for Europe, 3: AB/Inch configuration (6R5E) for Asia, Oceania, South
                America
                Default value= The default differs according to the location.
                U NEED A MANUAL FOR OTHER SETTINGS
                • sudani19
                  • Jun 2009
                  • 27
                  UR helpful man teckat
                  thanx 4 the these replies , but ist the same procedure to entter service mode for irs or there is another one coz its not get me in service mode
                  • zoraldinho
                    • Mar 2008
                    • 5015
                    Pres 2 and 8 together in the same time.Check if you using settings button.
                    • teckat
                      • 16083
                      don't forget to check your service label settings ?
                      the IRAD Series machines need to be set up following their install procedure ,
                      or u will have issues
                      this model is a much different Box than the iR series,
                      u need proper Training & a Manual
                      • sudani19
                        • Jun 2009
                        • 27
                        Finally its solved . Iget in service mode and set the the size to setting (2) and every thing is OK
                        THANX again brother TECKAT ur ahero
                        • teckat
                          • 16083
                          Welcome
