Canon IR 5000 Hard Disk Clone - Help Required
  • mfdarvesh
    • Apr 2011
    • 24
    #46
    Re: Canon IR 5000 Hard Disk Clone - Help Required
    Originally posted by wildan_w2
    I use Paragon Harddisk Manager to clone and I always succeed in cloning harddisk, even with different size. The tricks are; you have to delete the partition first and reformat it. Finally you have to check the option of HDD raw copy in advance setting.
    Thank you very much, I will give it a try
    • adhy
      • Feb 2011
      • 109
      #47
      you are need canon firmware and SST to solve your problem.
      • spectraindo
        • May 2008
        • 313
        #48
        It's not easy to use SST if you have harddisks types not registered in the SST.
        The easiest way is harddisk cloning, you can use any harddisk, any size, as long as you make the exact copy of the partitions.
        • adhy
          • Feb 2011
          • 109
          #49
          i got this from The Senior tech you deserve to try it.
          • gensys
            • Jan 2011
            • 323
            #50
            The Road will be Mastered by >>> the Going...
            • mfdarvesh
              • Apr 2011
              • 24
              #51
              Off course, but both are not available and no one can share with me, possibly due to share restrictions. So I have to solve my problem through cloning.
              Yes, this is the only solution
              [ATTACH=CONFIG]11103[/ATTACH]
              Thank you very much, really valuable information you have shared
              • mr.daus
                • Apr 2011
                • 98
                #52
                I have read many posts on above topic but don't able to solve my problem
                I have two Canon IR 5000 Photocopiers, one of the Hard Disk is physically damaged, both HDs were 20 GB each.
                Now the only disk available work on both the machines, I have a 80 GB Branch New Disk, I have tried Norton Ghost, Acronis and Paragon Partition Manager to clone HD.
                Machine starts, Canon logo displayed and half of progress bars fills then an error displayed, I have gone through the error details its suggests problem in HD
                Please help me which software may I use to clone the only HD for use at other machine.
                mfdarvesh@hotmail.com
                both your machine may have different versions so that any different hadrdisk
                firdaus +(62)8195002007 firdaustrish@ymail.com
                • Troy
                  • Feb 2011
                  • 22
                  #53
                  This may not be helpful, but try setting jumper on the new blank HDD to slave when writing the image. Then set it to cable select or master when installing in the copier. Also if using Paragon try checking the box next to "Copy and resize partitions proportiinally".
                  I would say this has worked for me, but that would be incriminating wouldn't it?
                  • spectraindo
                    • May 2008
                    • 313
                    #54
                    Better use External USB to IDE cables to avoid jumper settings problems.
                    I've done this many times and good results.
                    The destination HDD must be equal or bigger size than the source HDD.
                    • gensys
                      • Jan 2011
                      • 323
                      #55
                      • ancet@rhoneduplication.fr
                        #56
                        I own a CLC3200 and I want to clone the HD. I bought the SST v.4.11E . Now, how shall I connect the PC to the CLC ? Do I need a crossed ethernet cable and connect it to the ethernet port. Or, is there any USB socket ?
                        Tks for any reply.
                        • spectraindo
                          • May 2008
                          • 313
                          #57
                          You cannot clone a HDD using SST, you must use HD Clone software like HD Clone from Miray software AG.
                          Take out the HDD from the CLC, hooked up in a PC and clone the HDD.
                          • rado_hristov
                            #58
                            You can copy Hard DD that work under Linux to mew one . Thats work . There is no way clone information on HDD whth another program . This is the way to solve prolem whtout SST & System software .
                            • jiongpao
                              • May 2009
                              • 413
                              #59
                              Download the HDClone software and clone your hardisk. Its work for me, tested
                              • ts-lx
                                • May 2011
                                • 59
                                #60
                                winhex
