Ir 4570 pick up the paper slow from a4 trays????
  • SESHU
    • 163
    #31
    Re: Ir 4570 pick up the paper slow from a4 trays????
    thank you..
    i will find out where to get those new model parts.
    • SESHU
      • 163
      #32
      any one post the pics of new model tray changed parts...
        • 16083
        #33
        replace the vertical path rollers with a gray one.
        GRAY VERT roller.JPGIt is same part number FB6-4852-000
        SEE PDF FOR OTHER PICTURES & INFO
        click on pdf to open>
        TP07.pdf
        • SESHU
          • 163
          #34
          [ATTACH=CONFIG]11388[/ATTACH]It is same part number FB6-4852-000
          [ATTACH=CONFIG]11389[/ATTACH]
          Thank you teckat for helpful reply.
          so can i change grey rubbers instead of white rollers or change fully doors and etc.....
            • 16083
            #35
            Picture was an example from another model
            Grey rollers are shown in Picture/ u change from the Black ones to Grey
            • mrfixit51
              Lead Service Technician
              • 1975
              #36
              You replace the roller shaft assembly. Cassette 1 paper feed assembly must be completely removed to access the top vertical path roller. While you have # 1 out of the copier, you can replace #2's roller while the assembly is still mounted in the copier. Replace them both! Replace the door assembly and the inner guide in cassette 1. While you are at it, and you have the #1 assembly removed, upgrade the pre-registration sensor actuator with one that has the metal sheath over it, and you now have the equivalent of a 3045 paper path, that will reward you with far fewer jams...
                • 16083
                #37
                • SESHU
                  • 163
                  #38
                  [QUOTE=teckat;241170]hto_fig_approve2.jpg[/QUOTE
                  Thank you mrfixit and teckat.
                  • SESHU
                    • 163
                    #39
                    Thank you for all members.
                    Here not available what ever choosed new model of doors and rubbers and tray assembly's seperatly.
                    i am searching around my nearest cities. Everybody says no... no... no...
                    Finally i set this problem in those A4 trays.
                    There is no paper jams in A4 tray sides.
                    i'm not changing any new model doors and grey rubbers and anything..
                    Deeply reasearch and set it up. Those A4 trays super worked.
                    after then ....
                    i load the work non stop continuesly around near 50000 copies. (beleive or not)
                    Day and Night its works great. No paper jams. No error codes. No quality down. Its completly works better without paper jams.
                    Still running successfully. i'm Very happy solved this problem.
                    Recenlty 3 mechines i set it above this type of tray problems. its works fine.
                    Than k u all.
                      • 16083
                      #40
                      http://www.wackyuses.com/ClickFixItMagic.jpg
                        How did you fix it without replacing parts?
                        • zoraldinho
                          teacher-guide-expert-guru
                          • Mar 2008
                          • 5015
                          #42
                            • 16083
                            #43
                            • mramlawi
                              • Jul 2011
                              • 838
                              #44
                              I guess Some Miraculous just falll
                              Distinguished road makes you jewel in rough
                              • SESHU
                                • 163
                                #45
                                [ATTACH=CONFIG]13788[/ATTACH][ATTACH=CONFIG]13789[/ATTACH]
                                what's the meaning of above picture????
                                you are not believe me ????
                                really i set it up mechine.
                                today also i checked once again... running successfully. no jamming.
                                any way thank's again teckat.
