8500 thin black lines
  • Piter
    • Aug 2025
    [CQ] 8500 thin black lines
    thin line appear in main scaning direction after long series of printin
    i supose the cleaning blade was the problem
    any suggestion??
  • teckat
    • 16083
    any suggestion??
    Main Scan is not the paper feed direction
    Paper feed direction is the Sub Scan direction
    see example below from iR5180
    • teckat
      • 16083
      any suggestion??
      Replace Blade / Check to see if the Drum Heater is coming on/ AP Kit ????
      also it
      may be caused by the waste toner not being moved from directly behind the drum cleaning blade to the waste toner auger because of a waste toner drive assembly failure. To diagnosis this failure open the front door of the imageRUNNER 105 / 8500 / 7200 and then remove the purple cover that is in front of the AP kit. When a copy is made the white gears on the front of the AP kit should rotate. If they do not the waste toner drive assembly has failed and requires replacement.
      what is your Firmware ver. ?????
      there was a DCON v40.92 update for blade lines in 2006
      • Piter
        Tanks
        I will check that tomorow morning
        • charm5496
          • 2387
          usually cleaning the ends of the drum, polishing the drum surface and a new drum blade will do the trick. Also make sure your exhaust filters are clean to keep the internal temperature down!
          • Piter
            I replace the cleaning blade and clean the end of the drum.
            Everything work fine
            Tanks you all
            • teckat
              • 16083
              Tanks you all
