iRC3170 - replacing HDD, firmware update
  • cuseeo
    • Jun 2011
    • 19
    Hello
    Printer Canon iRC3170, after replacing the disk and uploading software (+ language, RUI, etc.), the printer will not start. A progress bar appears, comes to the middle and the device does not respond.
    Please help, what am I doing wrong?
    greetings
    Jacob
  • charm5496
    • 2387
    Re: iRC3170 - replacing HDD, firmware update
    check your connections on the main controller. reseat your RAM and boot rom. When yoyu installed the firmware did you overwrite all?
    • cuseeo
      • Jun 2011
      • 19
      Yes, I did. I formated HDD and installed firmware with overwrite all.
      How can I reset RAM and boot rom?
      greetings
      Jacob
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        Tipe of disc?
        Firmware version?
        • cuseeo
          • Jun 2011
          • 19
          HDD - Seagate ST340014A
          Firmware ver. 40.01
          greetings
          Jacob
          • cuseeo
            • Jun 2011
            • 19
            I bought this device without a disc already. The previous owner probably dismantle the disc for save private data.
            greetings
            Jacob
            • teckat
              • 16083
              make sure u have only one version of SST on Laptop
              remove the memory/ clean ends & re-seat it
              iRC3100 SERIES
              Supported HDD's in the new HD-Format_v00.12 ITF File
              your's is listed below/
              where did u purchase this HDD from HDWN 'IC35L040AVER07-0
              HDWN 'IC35L040AVVA07-0
              HDWN 'IC35L060AVER07-0
              HDWN 'IC35L080AVVA07-0
              HDWN 'QUANTUM FIREBALLP AS40.0
              HDWN 'QUANTUM FIREBALLP AS60.0
              HDWN 'FUJITSU MPG3409AH E
              HDWN 'Maxtor 4D040H2
              HDWN 'SAMSUNG SP4002H
              HDWN 'SAMSUNG SV4002H
              HDWN 'MAXTOR 6L040J2
              HDWN 'MAXTOR 6L060J3
              HDWN 'IC35L060AVV207-0
              HDWN 'SAMSUNG SV0401H
              HDWN 'SAMSUNG SP0411N
              HDWN 'SAMSUNG SV0411N
              HDWN 'HDS722540VLAT20
              HDWN 'ST340014A
              HDWN 'ST340015A
              HDWN 'HDS728040PLAT20
              HDWN 'Hitachi HDS721680PLAT80
              HDWN 'WDC WD800BB-22JHC0
              HDWN 'TOSHIBA MK1665GSX
              HDWN 'Hitachi HTS545016B9A300
              • cuseeo
                • Jun 2011
                • 19
                I have only one version - 4.11
                iRC3100 SERIES
                I have only v00.09 ITF File
                Originally posted by Canon.Tech
                So you dont know if the machine was working before you bought it?
                Machine was working fine, I saw it before.
                There is one error during update:
                BROWSER... version up... error
                And should I format BOOTDEV or ALL, becouse if I try to run ALL format there is error message??
                Is 40.01 the newest version to iRC3170 ?
                greetings
                Jacob
                • zoraldinho
                  • Mar 2008
                  • 5015
                  Yes it is.
                  • teckat
                    • 16083
                    v40.01 is last version
                    I believe the 3170 uses a 80GB HDD & THE 3100 a 40GB HDD/ 40GB will not work in the 3170
                    The ALL_HDF batch file does NOT format the HDD. The HDD must be formatted by using the HDFormat file. On the newer model machines, you must connect to the device in 'Single Mode' to format the HDD with the HDFormat file.
                    If you replace the HDD on a machine, the HDD must be formatted using the HDFormat file BEFORE performing a batch install with the ALL_HDF batch file. Otherwise, the ALL_HDF batch install will fail.
                    sorry, that v00.12 Format file was for iRC3100 PRINTER
                    your HDD is listed in the iR3100 format file list- that does not mean it will be accepted in the 3170/ unless it was purchased from Canon as a OEM
                    when u select SINGLE to format the 3170 HDD - what is the SST error message EXACTLY
                    your HDD may not be supported for the iR3170/ The HD Format v00.09 .itf file is encrypted , so u are not able to see supported HDD's
                    if u did not purchase this HDD from Canon
                    • cuseeo
                      • Jun 2011
                      • 19
                      Error response:Process has ended in error.
                      <<< FileName >>>
                      HDDFormatALL:C:\ServTool\iRCXXXX\HDFormat\XXxxv000 9\iRCXXXX-XXxx0009-HDFormat.ift
                      Module : SendFile() - 5
                      • cuseeo
                        • Jun 2011
                        • 19
                        I changed disk to WD Caviar WD800 (80gb), unfortunately is the same effect.
                        These disks are NOT provided by Canon, it's normal disk from PC.
                        Any ideas ?
                        greetings
                        Jacob
                        • cuseeo
                          • Jun 2011
                          • 19
                          Okay, I know that I should prapare hard disk to work in this machine. Can anybody help me?
                          greeting
                          Jacob
                          • charm5496
                            • 2387
                            the HDD format has to be done at the machine through the SST for the firmware to load. Where did you get the firmware for this unit? Did you go in and modify the ift file? If so make sure it is in a read only format after changing it. The Western Digital HDD should be supported, but if it is not you have to put the SN of that HDD in that file so the SST can read it.
                            • teckat
                              • 16083
                              greeting
                              Jacob
                              How exactly are u using the SST to format this HDD ?????
                              for the iRC3170
