I have a Canon IR3300i model which leaves a smudge mark or band about 1 inch wide and 10 inches long. It leaves it on LTR and 11x17 sizes only off the glass. Works fine when printing and through the feeder. Tried cleaning the mirrors and all optics. must be missing something.
Canon IR3300i leaving smudging only on LTR and 11x17 off the glass
Re: Canon IR3300i leaving smudging only on LTR and 11x17 off the glass
from Canon support site
"Quoted"
When using the ADF, the document is center referenced. Off the glass, the document is referenced to the upper left hand corner of the glass. Thus, the copies made off the glass use different pixels off the CCD than through the ADF.
Check the door specs settings for ADJ_XY in service mode under ADJUST. Someone could have changed them. If those adjustments are correct, the next thing I would do is check horizontal registration. If that is correct, the next thing to do is to change the CCD. I am assuming that you have thoroughly cleaned the optics and the CCD.**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Check the door specs settings for ADJ_XY in service mode under ADJUST. Someone could have changed them. If those adjustments are correct, the next thing I would do is check horizontal registration. If that is correct, the next thing to do is to change the CCD. I am assuming that you have thoroughly cleaned the optics and the CCD.Comment
