canon clc 2400
  • kofi
    canon clc 2400
    this machine gets to ready to copy mode but when u start copying, error message E061-X315 comes up and no image gets produced on the paper. need help
    • 23010
    I've never worked on the color Canons, but I can tell you that the E061 means that the grid bias has hit its upper limit. This means that the potential control is attempting to compensate for some primary charge related problem.
    That's about as much as I can help.
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      I found this on the canon website.
      Problem :
      E061 / 0312 error codes can be caused by a bent process unit connector mount for J6183 because it interrupts the Potential Control signals to the DC Controller
      Solution :
      Straighten or replace connector J6183 which is located on the front left chassis of the process unit.
