Canon np6050
  • abi
    • May 2025
    [Jamming] Canon np6050
    Hi, My canon NP6050 alway paper jam at drum unit, 1 change my corona wire and it casing, but the still jam. tq.
    • 16083
    Re: Canon np6050
    Separation jams will be frequent if the corona current output to the transfer/separation charging assembly is stopped because of an over current.
    No warning will be issued to the control panel in response to this condition; if separation jams are frequent, check the relevant mechanism.
    If an over current flows into the separation/pre-transfer charging assembly, the high-voltage
    transformer stop signal (HVTOFF) is generated to
    cut off the corona current (DC/AC component)
    temporarily to the pre-transfer/separation charging
    assembly.
    When the HVOFF signal is generated, the
    copier continues to operate; application of the
    corona current will be resumed once the application
    voltage returns to normal.
    check Pre-Transfer & Separation
    As many as 17 sensors are used to monitor the movement of copy paper
    PS08 -Holding tray feeding assembly 1 paper sensor
    PS09 -Holding tray feeding assembly 2 paper sensor
    PS10 -External delivery sensor
    PS12 -Internal delivery sensor (reversing assembly)
    PS14 -Holding tray registration paper sensor 11
    PS15 -Holding tray inlet paper sensor
    PS17 -Holding tray pick-up sensor
    PS22 -Multi-feeder pick-up sensor
    PS23 -Registration paper sensor
    PS24 -Pick-up vertical path 0 paper sensor
    PS27 -Pick-up vertical path 3 paper sensor
    PS30 -Pick-up vertical path 4 paper sensor
    PS33 -Pick-up vertical path 1 paper sensor
    PS36 -Pick-up vertical path 2 paper sensor
    PS47 -Fixing assembly outlet paper sensor
    PS49 -Left deck outlet paper sensor
    PS52 -Claw jam sensor
    • CaptnRed
      • Apr 2011
      • 57
      Re: Canon np6050
      What is the jam code?
      In service mode *1* tab 5/9, this shows the last nine jam codes in the body of the machine.
      Can you describe the type of jam? Z-fold? curled on drum?
      • COPIERTEC ASSOCIATES
        • Aug 2011
        • 279
        Re: Canon np6050
        Check pre transfer and seperation current from the secondary HVT,try to disconnect the cable entering pot labelled Q on the secondary HVT,for possible leakage,ensure that connections to the main HVT are ok.
        • abi
          Re: Canon np6050
          assembly.
          thank you for your information. i think my machine over current.
          • abi
            Re: Canon np6050
            tq, sometime Z-fold, sometime curled on drum. No jam code appear on the panel. i suspect problem with the over current to the corona wire.
            • mdm7266
              • Dec 2007
              • 99
              Re: Canon np6050
              what is the solution to the over current? any Remedy?
                • 22943
                Re: Canon np6050
                I still don't know what the original jam code is. There's really nothing to talk about until that little bit of information comes to light.l =^..^=
                • mdm7266
                  • Dec 2007
                  • 99
                  Re: Canon np6050 frequent jam at drum area
                  what is the remedy/solution to the problem?
                  • roller
                    • 26
                    Re: Canon np6050
                    Try to replace PRE TRANSFER corona unit. It could cause those jams too.
                      • 16083
                      Over current protection starts from your OUTLET-
                      If the Printer is not on it's own dedicated supply line, you can experience fluctuation in voltage.
                      Power disturbances may be called a surge, sag, spike, swell, transient, fluctuation, interruption, or electrical line noise. All these disturbances are abnormalities and deviations from the normal performance of voltage sources. They may last for a short period, a long time, or be continuous.
                      This all depends on your country standards & regulations.
                      You never know what or who is using/overloading that source outlet until u contact building electrician
                      Basic Surge Protection- those inexpensive "surge protected power strips" are a waste if u have constant up & down power surges at your location
                      AUTOMATIC VOLTAGE REGULATORS
                      --automatically increases low utility power and decreases high utility power to a consistent and safe 110/120 volts. If incoming utility voltage drops below 90 volts, or exceeds 140 volts the units automatically switch to battery back-up power.
