IR3170 Dirty soiled background
  • COPIERTEC ASSOCIATES
    • Aug 2011
    • 279
    Hello guys am working on the above color machine.When i photocopy in both black and color,the copies come out with a dirty soiled background. I have changed the drum and cleaning blade the problem has persisted.What could be the problem? Thanx in advance
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5017
    Re: IR3170 Dirty soiled background
    Do you have a new type of the Transfer Cleaner?
    Old FM2-0082-020 TRANSFER CLEANING ASSEMBLY
    New FM2-0082-110
    Old FC5-0467-000 SUPPORT, PRESSURE RELEASE
    New FC5-0467-020
    • teckat
      • 16083
      Are your Network prints clear ????
      Background when copying from the glass only ????
      Check & Enter the value indicated by the bar code found at the upper right on the copyboard glass./Enter in service mode
      What type of originals are u copying ??
      NOTE: if issue is on all Prints & Copies
      U may need to replace>
      Main controller PCB (sub PE-A) pcb
      FM2-3678-000/ board controls (background removal)
      • fchu5959
        Field Engineer
        • Jun 2010
        • 100
        Hi,
        How about posting a photo of the problem.A photo replaces a thousand words.
        cheers
        • teckat
          • 16083
          Originally posted by fchu5959
          Hi,
          cheers
            • Aug 2011
            • 279
            Thanks comrades for your suggestions i will be going back on site 2morrow. Thanks!
