Hello guys am working on the above color machine.When i photocopy in both black and color,the copies come out with a dirty soiled background. I have changed the drum and cleaning blade the problem has persisted.What could be the problem? Thanx in advance
IR3170 Dirty soiled background
Re: IR3170 Dirty soiled background
Do you have a new type of the Transfer Cleaner?
Old FM2-0082-020 TRANSFER CLEANING ASSEMBLY
New FM2-0082-110
Old FC5-0467-000 SUPPORT, PRESSURE RELEASE
New FC5-0467-020If it ain't broke, don't fix it
A picture is worth a thousand words -
Background when copying from the glass only????
Check & Enter the value indicated by the bar code found at the upper right on the copyboard glass./Enter in service mode
What type of originals are u copying ??
NOTE: if issue is on all Prints & Copies
U may need to replace>
Main controller PCB (sub PE-A) pcb
FM2-3678-000/ board controls (background removal)Last edited by teckat; 11-04-2011, 04:33 PM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
How about posting a photo of the problem.A photo replaces a thousand words.
cheersComment
Thanks comrades for your suggestions i will be going back on site 2morrow. Thanks!Comment
