Canon IR-6000
  • copyman
    Owner / Technician
    • Sep 2005
    • 4732
    Canon IR-6000
    Anyone know what would cause these marks on pages (see attachments)? Happening all the time printing or copying.
    Removed process unit and everything looked good, including drum.
    Stopped page mid-cycle and marks on copy before fuser.
    Samples were run 11 x 8.5 with marks on edge of paper toward front of machine.
    Any help appreciated.
    Thanks in advance
  • doktor
    • 214
    Re: Canon IR-6000
    Check developing assembly.Developing sleeve unit-fg5-8235-000 is sucks.
    • sweet.persona
      Engineer
      • Nov 2009
      • 414
      Re: Canon IR-6000
      Hi,
      If this happened after you cleaned the machine (and it was OK before) retrace what you did, remove & check any items you removed or cleaned. ------Especially developing unit
      A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
      DAMENE ABDEL AZIZ
      DJELFA
        • 23010
        Re: Canon IR-6000
        You've definitely got primary charge discharging somewhere it shouldn't. =^..^=
        • copyman
          Owner / Technician
          • Sep 2005
          • 4732
          Re: Canon IR-6000
          Thanks for the replies. It was doing this before I cleaned the machine. Customer called and said machine started doing it all of a sudden.
          • Mina Banoub
            • May 2011
            • 50
            Re: Canon IR-6000
            Hi,
            replace the developing cylinder or the developing assembly.
            • livancicm
              • Sep 2008
              • 96
              Re: Canon IR-6000
              FB6-6569-000 roller spacer
              • mramlawi
                • Jul 2011
                • 838
                Re: Canon IR-6000
                Check the cylainder spacer and also try to change the drum blade once happend with me and i change the blade try it
                Distinguished road makes you jewel in rough
                • montana
                  • Aug 2008
                  • 392
                  Re: Canon IR-6000
                  hi...yes sir it is happened with me once i replaced the developing assembly which corrected that image
                  fault...the HVT board causes this fault also
                  good luck
                  • COPIERTEC ASSOCIATES
                    • Aug 2011
                    • 279
                    Re: Canon IR-6000
                    The major cause of this phenomena is the worn out spacers of the dev unit.I have encountered this problem many times and replacing the spacers has always solved it
                    • arielcanon
                      • Mar 2012
                      • 106
                      Re: Canon IR-6000
                      I agree with CopierTec..., wornout spacer. replace with new one
                      Learning never ends..
                      Never give up, where there is a wheel there is a way..
