CANON iR2016
  • iali307
    • Aug 2025
    CANON iR2016
    I just replaced the fixing film two days before and it is shocking for me the error E007 is back and fixing film damaged ,prior to E007 system error E001 was coming three-four times.what can I do in this situation ? tHE fixing/fuser assembly replacement is ideal solution for all these problems?
  • lkrsardis
    • Dec 2007
    • 316
    This unit is a little difficult to repair. So replacement should be considered.
    Like the United States Postal Service It's a miracle it works!
      • 23009
      I replaced exactly one NP6016 fixing film. It took nearly two hours to get the thing back together and tension balanced. It was definitely not worth it.
      • lkrsardis
        • Dec 2007
        • 316
        I checked Canon's esupport about their exchange program and this model is not listed yet as of yesterday. They have this program where you send in your old fuser and they rebuild it and send it back at a lower cost than a new one, the trick is to buy a new unit to start yourself a core program,because the turnaround time is about a week. I'll post it when they start the 2016 line, it should be soon.
        • Hombre
          Service Engineer
          • Jan 2008
          • 24
          Did you checked the bushings from pressure roller ? If they are used, pressure roller applies uneven force to film, causing the film to slip.
          • Irish
            • 110
            Just Change the unit ..... Life is to short
