So the service manual says a scanner homing issue...all errors have been cleared..it seems to work but there must be an adjustment ...what could that be....thanks
canon ir 5075 error 0202 and 0101
Re: canon ir 5075 error 0202 and 0101
E202-0101
re-seat the ROM on the Memory pcb board shown in Figure 410.
**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
That is how the error log showed it....person said it happens when scanning to email...puts paper in dadf presses start ...gets a click noise and the display says powering down...i have cleaned the feed ..dadf ..rollersYou never realize how cheap a professional is until after you let an amateur do it....and
if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!Comment
Also where is this Rom board as my phones display is small and searching is challengingYou never realize how cheap a professional is until after you let an amateur do it....and
Hi!! E202>> Motor belt tension adjustmer.
Hangul, so I'm sorry.Attached FilesComment
so I got the boards out but there doesnt seem to be a rom chip socketed on them to reseat.
Also Teckat what do you think about the belt tension adj?
ThanksYou never realize how cheap a professional is until after you let an amateur do it....and
have only done a belt tension on iRC5185 DADF T1.
/works on that model/do not over tighten
memory.JPG**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
perfect...i see where the memory is down and under....never would have looked there...also on the belt adj, since the ins in chinese, why is the one picture showing fingures holding the black plastic cube and do you move the motor itself for tension
also i will reseat the mem first and see what happins before anything else...ok?You never realize how cheap a professional is until after you let an amateur do it....and
So the memory and board was changed...no difference ..now for the belt adjust ..any updatesYou never realize how cheap a professional is until after you let an amateur do it....and
CANON
Error code E202 is occurring intermittently.
Workaround :
In this case, adjusting the drive belt tension for motor M6 in the DADF-S1 corrected the error. Note that M6 is the DADF-S1 CIS Glass shift motor.
SEE IN ENGLISH---BELT TENSION .pdf
Found some more issues>>>>>>>>
E202 0101 remained after following TP08 013 for belt adjustment procedure.
E202 0101 remained after replacing the CIS glass shift HP sensor,the glass shift motor
and the ADF controller pcb.
Solution :
Replacing the Driver PCB FM3-0371-000 in the DADF-T1 resolved the issue.
Error :
E202 - 0101 is indicated at power on.
The HP cannot be detected in the detection (outward) of the HP position of the backside reading glass (CIS).
The DADF controller drives M6 when necessary and moves the CIS glass. By executing such procedure, the DADF controller compares reflection data of the standard white plate position with that of the image scanning position, and executes the correction of shading and dirt detection.
Workaround :
PLEASE READ ATTACHED TECHNICAL PUBLICATION (TP08-013) FIRST!
Verify the operation of M6 and PI13 and replace parts consequently.
[1] Check M6 in PART CHECK> MTR-CHK> 5 for operation and verify the connection of J214 on ADF Driver PCB (PCB7).
[2] Check for PI13 sensor state in service mode FEEDER>I/O > P006 - 6 (0:HP) and verify the connection of J412 on ADF Controller PCB (PCB1).
PI13 - CIS glass moving HP Sensor WG8-5593-000
M6 - CIS glass moving motor FK2-3715-000
PCB1 - ADF controller PCB FM3-0369-000
NOTE: Before you replacing the ADF Controller PCB (PCB1), print a P_PRINT and see the description given under "After Replacing the ADF Controller PCB" on the host machine service manual.
If it only occurs when scanning to pc....and as the paper is placed in the dadf when the start is pressed...it fails right then....so far after belt adjust it works ...not much adjust thoughYou never realize how cheap a professional is until after you let an amateur do it....and
Rachid.
"Find a job you love and you’ll never have to work a day in your life." Nagy's fatherComment
So I adj the belt and they did the scans with no problem...I went back to the shop and they called...now there is a difference: the doc scanned and went to the PC and then the error came up...same error.....?????You never realize how cheap a professional is until after you let an amateur do it....and
I spent half a day to solve the same error code. The service manual says a scanner home postion issue. But, don't forget that there are two scanners: the classical one under the reading glass and the scanner inside the DADF. Both move to their home postion for gain correction. The DADF scanner moves on two parallel rails. Just clean and lubricate them.
Rachid.
