paper output at the end of half inch to 3/4inch there is an wave form (not flat) why ?
80lb texst coated
100lb test coated set at heavy 1
80lb cover coated set at heavy 2
80lb 100lb texst go by bypass tray set heavy 1
80lb text by pass heavy 1 --always jam at fuser
or 80lb ,100lb text set plain ---how about fuser
100lb cover pass through fuser ----result is nightmare return
all that is c3220 model
any suggestion are welcome thanks
80lb texst coated
