Canon c2880i lines
  • copier tech
    • 8133
    #16
    Re: Canon c2880i lines
    I'm guessing you're not a tech!?
    99.9% of the time lines on this model are caused by the drums.
    Have a look at the condition of each drum, you can probably see lines on the drums.
    • Acme
      • Jan 2013
      • 155
      #17
      Dang it, ya got me, Toshiba guy here if you didn't read the thread. Thanks for the 2cents and the Ad hominem.
        What is the life of the drums service mode > display > misc
        If you do replace the drums run a full auto gradation as described earlier and in service mode there is also . function > cleaning > trns clean
        what this does is places a layer of yellow toner on the transfer roller. The layer should be uniform across the roller.
        • northernlife
          • Sep 2011
          • 847
          #19
          function > cleaning > TNR-COAT lays the yellow toner down on the 2nd trans roller to prevent particles from sticking to the ITB and causing white spots
          2TR-CLN is used when the sheets are smudged or dirtied by the 2nd trans roller
          • Acme
            • Jan 2013
            • 155
            #20
            Thanks for the help guys, Waiting on the customers corporate to approve the cost.
            Thanks again
