the printer first restarts when I start printing
  • win32
    • 19
    hello i its a canon irc5185i , when i run the print it it freezes then restarts , but when i copying its ok
    • 23010
    Re: the printer first restarts when I start printing
    How long is this "freeze"?
    When you send a print job, the first thing the MFP does is start warming up the engine. If the print data has completely arrived by the time the engine is warmed up, it prints immediately. If the machine is still receiving print data when warmup is complete the engine will remain warmed up, but turn off motors in anticipation of receiving the first complete page of print data. In essence, this sounds to me like you've got a slow network connection.
    • win32
      • 19
      I think not, since even the test print does not work properly and it gives me an encrypted print (Local printing test)
        • 23010
        Please attach a sample.
        Are you using the exact correct Canon print driver for your OS? =^..^=
        • win32
          • 19
          the exact yes ,,i told you the trouble is the same when i print test from the machine not from computer ,,,,
            • 23010
            So you did. So ... please attach a sample.
            • win32
              • 19
              Here are two samples before and now in PS mode
              • teckat
                • 16083
                Originally posted by win32
                [ATTACH=CONFIG]24287[/ATTACH][ATTACH=CONFIG]24288[/ATTACH]
                Remove> clean ends & reseat all the PCB's on the main controller
                sometimes u get various errors & sometimes u get a digital mess (as shown on t print)
                pdf lists error issues/ but I have seen sub boards cause Print Issues
                see pdf-----Board Cleaning_Board Position-TP07 094.pdf
                • win32
                  • 19
                  see pdf-----[ATTACH]24289[/ATTACH]
                  [ATTACH=CONFIG]24291[/ATTACH]
                  [ATTACH=CONFIG]24290[/ATTACH]
                  hello i tried to clear all of composants ,, exept SRAM circuit board but the trube rest the same , when i run the print job ;i have more than 5000 works,,,, some of theme notified NG 852,, i tried to clean all of these jobs ; but no way ;; i tried to renitialise the HDD , MN CON clear , mmi ..... but the prints job steel here ,, should i disconnect SRAM circuit board and re seat ????
                  • teckat
                    • 16083
                    Never seen a printer with 5000 prints stored in it.
                    Call for a trained tech to inspect.
                    • THUK
                      • Jul 2008
                      • 195
                      Replace the main power supply.
                      • Canuck
                        Tech Specialist
                        • 1713
                        Good luck.....don't understand you. Place a service call
