c5045 print quality bad
  • kei9tha
    • Feb 2014
    • 88
    [CQ] c5045 print quality bad
    i recently refurbished a c5045. new drum units, new itb assembly with new belt, ans everything else feed tires and so on. the only thing i did not change is the transfer roller, i am told that the transfer roller never goes bad and that is that. so says the man who signs my checks. if i print from the machine i get perfect prints. when the customer prints the copies come out with light lines on gray scale and when in color there is purple and faint yellow lines going across the page. i have added a attachment to show you what i mean. i tried to do the auto graduation adjustment and it has made no difference. although i am new to canon i am not new to refurbishing machine or color machine either. any help is greatly appreciated.
  • northernlife
    • Sep 2011
    • 847
    Re: c5045 print quality bad
    Clean the laser with the wand that's on the door.
    • CanonSco
      Man About Town
      • Jul 2010
      • 368
      Both the internal ( on the ITB assy you replaced ) and the 2nd external ( large foam type on RHS door ) transfer rollers do wear out and need replaced. That does not look like your issue on the attached scan. As said the deletions will more than likely dirty lasers. It is hard to see if you have other quality issues on that scan.
      I only replace those rollers at failure, not on the counts.
      Yes, I am a nerd.
      Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
      • THUK
        • Jul 2008
        • 195
        yes dirty lasers,it is worth taking lasers out and clean mirrors and polygon mirror.
        • kei9tha
          • Feb 2014
          • 88
          it turned out to be corrupt file they were printing. after cleaning the laser units nothing had changed on the copies. so dig a bit deeper and the pdf file was no good. alot of time used up but at least ill know for the future that the laser units are spotless. thanks for the help.
          • copier tech
            • 8133
            Also as you said if you print to the machine "you get perfect prints"
            On any make or model this is the same, if your test prints are perfect then suspect an original/PDF or driver issue
