Red ground wire from fixing film unit
  • Brian8506
    • 1664
    Re: Red ground wire from fixing film unit
    Should be a printer reset in sm somewhere. Try getting a manual from Paul at www.justmanuals.com. I don't have one or I'd look it up for you.
    • northernlife
      • Sep 2011
      • 847
      There isn't on the 2020's. The only err code related clears are for coin reader options.
        • 8136
        1. I've sent you the manual.
          To reset the error do this:
          Press ADDITIONAL FUNCTIONS, #
        2. Go to #7 Printer and press OK
        3. Go to #4 Printer Reset and press OK
        4. Yes = ( * )
        5. Power cycle unit.
        • brunno1968
          • Apr 2014
          • 19
          #19
          Hello all,
          Thank you for all of your answers.
          I have not received the manual. I tried the method to clear the code but the menu is different and i can't follow the steps !
          Additionnal function, # = bip,bip,bip
          Go to #7 = report setting
          The copier is a Canon Image runner 2018.
            • 8136
            #20
            Read the manual!
            Abcslot merupakan situs SITUS ABCSLOT dengan fitur mahjong super scatter x1000 yang tidak diragukan lagi kegacorannya di muka bumi
            • northernlife
              • Sep 2011
              • 847
              #21
              4. Yes = ( * )
              What he said ^ :-)
              • brunno1968
                • Apr 2014
                • 19
                #22
                I have already this manual. I have read a lot but i can't see exactly what i have to do ! I did a lot of search with words like '' fusing, reset, clearing error '', tried a lot of things but nothing happened ????? May be i have connected something at the wrong place ( i don't think so but who know ! ), i will re-install the part for a second time !
                • brunno1968
                  • Apr 2014
                  • 19
                  #23
                  I just reinstall all parts.....Error system E000 and E003 appears again.....I did :
                  1. To reset the error do this:
                  2. Go to #4 Printer and press OK
                  3. Go to #10 Printer Reset and press OK
                  4. That return to principal screen ( not yes =(*) )
                  Probably there is an other problem !
                  I have to say that I didn't change all fixing film unit, only the round tube.....May be that is the problem ?
                  • Brian8506
                    • 1664
                    #24
                    What was the original problem? E007 would be the film. E000, 001 would be upper assembly
                    • brunno1968
                      • Apr 2014
                      • 19
                      #25
                      At the beginning, the problem was E007 i changed the film only( it had a lot of crack on the sides ). I kept the old sides items, i removed the film and insert a new one ! After that, codes E000 and E003 appeared. I tried to reset the code but i am still not able.
                      • Brian8506
                        • 1664
                        #26
                        Sounds like something's not connected or connected properly if you're getting those codes and they won't reset. If not, you may have to replace the upper assembly.
                        • brunno1968
                          • Apr 2014
                          • 19
                          #27
                          Hi, Thank you for your answer. I checked all connection and everything look fine. In attach, 2 pictures, could you tell me which one are you talking about ? The first one is : fixing film assembly and the other is fuser fixing assembly.fixing film assembly.jpgFM33651.JPG
                          • Brian8506
                            • 1664
                            #28
                            Fixing film assembly on left. Whole fuser would be easier but much more expensive.
                            • brunno1968
                              • Apr 2014
                              • 19
                              #29
                              Thank you Brian8506. I will order one monday morning. I will let you know what will happened. Have a nice weekend.
                              • brunno1968
                                • Apr 2014
                                • 19
                                #30
                                The fixing film asembly was the provlem....i changed it and everything is working now.
                                Thank you all
