Print quality of iRC3080i
  • tee2520
    • Jun 2013
    • 37
    [CQ] Print quality of iRC3080i
    The example and test PG10 as above, please advise.Thank you
  • ernesto
    • Oct 2011
    • 430
    Re: Print quality of iRC3080i
    Originally posted by tee2520
    [ATTACH=CONFIG]26930[/ATTACH]
    [ATTACH=CONFIG]26931[/ATTACH]
    Hi, it could be useful
    http://www.copytechnet.com/forums/ca...ck-solids.html
    Once all of the above is done...... it has been said that it could be HVT 2 (high voltage pcb number 2 )(FK2-0489-000).
    All the best
    • copier tech
      • 8144
      Yes this is the same fault I have, not quite as bad, I would start with a new OEM drum, even if it is not yet up to 100% if the drum fixes the fault you can rule out a charge/HVT fault.
      If the fault returns look at toner supply issues.
      What does the K DENS % show? should be around 0%, -4% means low black toner density
