Life of drums black in the iRADVC 20/22xx series.
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    Hi to everybody !
    A simple poll: Drums K in iR ADV C20 / 22xx series can make their life cycle or last a lot less?
    I speak of machines installed only and EXCLUSIVELY office (no graphics).
    Thanks !
  • JPiek
    • Oct 2014
    • 435
    Re: Life of drums black in the iRADVC 20/22xx series.
    Originally posted by Ingranaggio_rotto
    Hi to everybody !
    Thanks !
    Depends on how picky the customer is... Most of the times it's on -85 when errors occur.. Sometimes +90
    rarely +100
    Johan
      • 8172
      I agree, rarely see them hit 100% major design fault on this series
      • jai_landrover
        • Apr 2011
        • 2
        Cleaning blades fail inside the drums frequently especilly when doing solid black and it repeats had this from 25% to 70% Rarely do we ever get above 70%
          • 8172
          Thats the whole problem with these drum units, they dont have a drum blade! Drum cleaning is done by charge!
          • JPiek
            • Oct 2014
            • 435
            So it's actualy some electrical part that fails ? I doubt it, i often see lines on the surface of the rolls...
            Johan
            • MFPTech
              • 486
              Hi to everybody !
              Thanks !
              Black Drums fail quality wise at 68%
              Color drums often fail mechanically wise very prematurely and it sounds like a main drive noise.
              Fusers and inner finishers are another story
              Either than that everything else is great!
                • 8172
                I had a custmer that had some urgent printing to be done but k drum unit was leaving lines & background all over the prints. I stripped & cleaned the unit & it ran fine for a couple of days untill the new unit arrived.
                • JPiek
                  • Oct 2014
                  • 435
                  Sound familiar but ony works for a couple of prints/days. I even told to do a int.cleaning twice a day, seems to help a bit to..
                  But that only works if the cleaning doesn't work, if the roll itself is damaged it doesn't...
                  Johan
                  • dan7777
                    • Dec 2012
                    • 680
                    Most of mine get 100% but not much over that. Some I have to replace just over 50% for offsetting/ghosting.
                    • Ingranaggio_rotto
                      • Oct 2010
                      • 275
                      In my machines rarely the drum K goes over 80 %, ( 70 % it's the medium life). And I'm speaking by installations in office ambient ! ! ! No graphic !
                      • ernesto
                        • Oct 2011
                        • 430
                        HI,
                        It is very important to update the lastest firmware and the drum life improve a little bit... at the moment it is the only solution that I know..
                        All the best
                        • vamoursly
                          • Sep 2011
                          • 273
                          At this point I will just laugh and say they are unpredictable, sometimes they go at 60%, sometimes I have seen them run to 150% (I just wanted to see how long a black would run for)
                          • Noiseless
                            I have some 20xx and 22xx and they all og to 100% and more before i change the drum.
                            Some of them are a bit gray but the custumer dont complain.
                            best reg.
                            • MFPTech
                              • 486
                              Originally posted by ernesto
                              HI,
                              All the best
                              The firmware doesn't do a thing .... Canon's latest remedy is a new style ITB and a few changes of settings in SM. Will try one today and see how it goes.
