Canon IR 2016 out of toner
  • mido
    • Nov 2011
    • 177
    Hi,
    I have a problem in IR 2016, showing (out of toner) or change toner,
    the toner bottle is full, I checked the development unit and the developing cylinder, all are ok,
    but I didn't found the sensor of the toner, how the machine knows if the toner is low or full???
    please I am waiting your kind reply,
    Thank you
  • ernesto
    • Oct 2011
    • 430
    Re: Canon IR 2016 out of toner
    Originally posted by mido
    Hi,
    Thank you
    http://www.copytechnet.com/forums/ri...ghlight=canon+
    • doktor
      • 214
      http://www.copytechnet.com/forums/ca...ner-error.html
      • mido
        • Nov 2011
        • 177
        I mean canon IR2016, not Ricoh Aficio 2016
        • ernesto
          • Oct 2011
          • 430
          Upppsss sorry about
          • copier tech
            • 8169
            This is usually simply dirty contacts on the back of the dev unit also check the dev unit is seated correctly, racking into to the drum unit ok etc..
            Failing this, vacuum out the unit completely, fit it back in the machine run copies & wait for the machine to ask for toner.
            • jrgf67
              • Feb 2010
              • 37
              Saludos. Deberias hacer un borrado general (clear+all) y si no funciona cambiar la unidad del revelador.
              Greetings. You should make a (clear+all) deleted and if it does not change the developer unit.
              • montana
                • Aug 2008
                • 392
                Hi,
                Thank you
                hi...you should adjust the vr on the HVT board which named ANT...to get the correct toner density
