Fuser temperature far too high on ir3570
  • Mark in England
    • Oct 2010
    • 47
    Hi all,
    just wondered if anyone had any ideas why an ir3570 would keep blowing fusers?
    The fuser overheats and cracks the element in the end.
    The temp is 230 to 240c on a run which is way too high.
    I've replaced DC controller and swapped the ac driver (long shot I know) from a known good machine. It's gone through 2 fusers now and I'm running out of ideas.
    Anyone else had similar??
    thanks in advance
    Mark
    • 22999
    Re: Fuser temperature far too high on ir3570
    Have you looked at the power?
    • Mark in England
      • Oct 2010
      • 47
      Hi
      Thanks for the reply
      The machine is in my workshop luckily so tomorrow my next step was going to be swap power supplies with a known good machine. Doesn't make sense though-the fuser runs off mains (220v) supply so you'd think the problem would be one of it not getting hit enough not too hot....worth a try though as most else has been ruled out.
      Cheers
      Mark
      • vigour
        • Aug 2010
        • 1038
        Check for an AC driver or Solid state relay problem
        • Mark in England
          • Oct 2010
          • 47
          Hi
          update on the fault although not really any further forward.
          We've been working on it today and have swapped from a known good machine:
          fuser assy
          DC power supply complete with AC driver
          DC controller
          full MMI and DC controller clear
          full HDD format and reinstall system software
          check all cable ties and wiring fuser to DC controller and DC controller to AC driver
          Still get the same high temperature 235c when it's running. Far too high and will blow the fuser if left unchecked. Should be around 205c when running.
          Anyone one have any ideas as I'm beginning to think it must be that it has a curse on it and only a blessing from a priest will cure it!!
          Cant see it being main controller but nothing really left.
          Any ideas guys please??
          cheers
          Mark
            • 22999
            Originally posted by Mark in England
            Hi
            fuser assy
            DC controller
            cheers
            Mark
            The main controller does handle the temperature signals, and possibly sending along false data. That's next. =^..^=
            • Mark in England
              • Oct 2010
              • 47
              Hi
              Thanks for the reply. I've looked in the service manual and there's no mention of the main controller having anything to do with temperature control but I am inclined to agree with you (mainly as I've replaced everything else!!).
              Do do you have any information about the main controller having anything to do with temperature control please??
              many thanks
              Mark
                • 22999
                The thermistors run directly to the DC controller. If you need footnotes it will have to wait until tomorrow. =^..^=
                • hachetman
                  • Jul 2009
                  • 96
                  there should be a triact (solid state relay) that on other models has been know to caused this type of problem
                  Steve Baker
                  hachet1_12@outlook.com
                  • Brian8506
                    • 1664
                    Gonna look at one today but I think they run hotter than 205. Maybe I'm wrong but if it's overheating why is there no error codes
                    • canon33
                      • Jun 2014
                      • 65
                      I also question why no e codes. Are u using genuine canon film? Are u replacing just the film or the film assy?
                      I don't see these much anymore but would love to hear if someone else can Ck one in the field . I'm betting its normal
                      • copier tech
                        • 8131
                        Yes I would expect it to throw an E001 etc error before it damages the fuser.
                        Change the fuser temp in service mode & see if it then maintains correct temp. FIX-TEMP set this to 2 (default is 0) 7 is the hottest.
                        I would also update the firmware to the latest version while you're at it.
