Canon Imageclass D1300 Black pages
  • Crystal
    • Jan 2013
    • 29
    [CQ] Canon Imageclass D1300 Black pages
    Does anyone know where we can get a service manual for a Canon Imageclass D1300? We have a customer that is getting Black pages and we need a service manual for this one...
  • teckat
    • 16083
    Re: Canon Imageclass D1300 Black pages
    partially blank orCompletely blank ??
    printing or copying or both
    did u check Drum, Transfer, Scanner ------------
    MF5900/D1300 Series
    Scribd Link
    • Crystal
      • Jan 2013
      • 29
      MF5900/D1300 Series
      Scribd Link
      copies are black when scanning and copying, but fine when printing. Our tech thinks it's the scanner assembly. It's probably cheaper for the customer to buy another machine.
      • teckat
        • 16083
        Sorry, misread on black>
        Yes u have a CIS issue,
        Leave up cover _ place a doc on glass_press copy & watch for CIS UNIT MOVEMENT & LIGHT Exposure.
          • 23010
          Even the void areas black? If it's a scanner issue the void areas will be intact (white margins).
          • Crystal
            • Jan 2013
            • 29
            There's a thin white strip on the right side of the page with uneven edges, but all of the other void areas that should be there are also completely black. One of our senior techs thinks it might be a ground problem with the toner cartridge.
              • 23010
              If you have any void at all, I suspect that the it is scanner related, but also that the image positioning and registration need to be adjusted to get the voids centered properly. Also the paper may be incorrectly positioned ... but none of that can be corrected until you get some of the original image. The contact image sensor is a good place to start. =^..^=
