Ir4570 problem on print double sided
  • jaruwit
    • Nov 2013
    • 10
    [CQ] Ir4570 problem on print double sided
    I found problem in print double sided with IR4570. on first page at right position to thin. second page is ok.
    Printing single page ok.
  • teckat
    • 16083
    Re: Ir4570 problem on print double sided
    [ATTACH=CONFIG]27571[/ATTACH][ATTACH=CONFIG]27572[/ATTACH]
    are u scanning these pages in with DF ???
    • Tonersniffer
      • Nov 2012
      • 74
      1. Change in SM Copier>Adjust>HV>TR-TP-LV to 0
      You might need to change the below setting but I doubt it:
      Change in SM Copier>Option>combo TR-SW1 through TR-SW5 to read 0 when you press TR-SW1 through TR-SW5.
      If it is humid and the paper jams in the drum unit, You might want to change this back.
      Help this helps.
      Tonersniffer
        • 23009
        It looks to me like flip.
        Especially when doing two-sided with moist/curly paper, the first side curls left. When inverted the second side approaches the drum with a right curl. As the trail edge of the paper passes it pulls away from the drum before it is fully transferred.
        The simplest solution is to carry in a fresh ream of properly stored paper, crack it open and run duplex test images. If it's really flip, the fault will be gone. Then you can advise them on proper methods of storing paper. =^..^=
        • jaruwit
          • Nov 2013
          • 10
          Yes I can from df?
          Image is as same as paper.
          I print on two machine IR4570. It the same result.
          I think. I ever found some document about this from canon Service Bulletin. But I lost it.
          There are change about electrode plate or some thing like that.
          • jaruwit
            • Nov 2013
            • 10
            Help this helps.
            Tonersniffer
            It work. change Copier>Adjust>HV-TR>TR-TP-LV to 0
            thank you.
            • Tonersniffer
              • Nov 2012
              • 74
              BlackCat,
              I agree with your flip theory on machines with corona wires for seperation but the same theory for machines with transfer rollers you might want to reconsider.
              Sincerely
              Tonersniffer
              • JoMaq
                • Jun 2015
                • 6
                Good day! I have a problem in printing from PC to IR4570 double sided, in that the 2nd page, the copy was upside down. Is there work around? Thanks in advance.
