Canon imageclass mf6550/ e197 error code
  • cucuklotz
    • Mar 2007
    • 611
    When I unplug machine for 5 minutes, the E197 message clears and machine says remove jam from side door area. I pull open and shut and machine resets. When I start copy again ,the E197 comes back. I have seen online much confusion as to what this code actually refers to .Does anyone know what actually causes this error code? THANKS ANDY
  • vigour
    • Aug 2010
    • 1038
    Re: Canon imageclass mf6550/ e197 error code
    What is your subcode i.e what four numbers or letters follow e197.
    It is different for different models.
    On this model , there is usually bad contact between the fixing frame connectors
    you could have a bent pin, or paper stuck in the connector.
    if you remove the finisher and left panels, you can watch to see of the connector is contacting the frame connector at an angle.
    Worse case, you may have to replace one or both connectors.
    • ernesto
      • Oct 2011
      • 430
      I had this problem once it was the fixing unit.... You can swap it to other machine....it is also said it could be the power supply.......
      All the best
      • Brian8506
        • 1667
        This is a desktop machine that uses plug in connectors
        • niyaskarimba
          • Sep 2014
          • 110
          Remove and re insert the fixing unit,only fixing unit connector problem
          • cucuklotz
            • Mar 2007
            • 611
            Hi. I appreciate the help,I will let you know how it turns out. Andy
