ir5065
  • akm
    • Sep 2012
    • 155
    [Dead] ir5065
    Dear/Copytechteam,
    Please i want your help to solve the problem with IR5065 that gives a white paper
    that i checked with another primary corona assy , deveolping tank but still gives that problem i record the setting .I send a sample
    DPOT-K=75V
    VL1T=75
    VL1M=82
    VL2M=80
    VDT=411
    VDM=406
    VL2M-P=90
    VL1M-P=89
    VL1T-P=75
    VDM-P=412
    VDT-P=411
    PRIMARY=467A
    PRE-TR=-50 microA
    TR=260A
    SP=-100microA
    BAIS=600V
    SP-N2=-100microA
    TR-N2=260microA
    THANKS
    AKM
  • jhoncrema
    • Jul 2014
    • 8
    Re: ir5065
    You try with other transfer corona assy, apologize my english
    Enviado desde mi iPhone utilizando Tapatalk
    • ernesto
      • Oct 2011
      • 430
      Re: ir5065
      Originally posted by akm
      Dear/Copytechteam,
      DPOT-K=75V
      VL1T=75
      VL1M=82
      VL2M=80
      VDT=411
      VDM=406
      VL2M-P=90
      VL1M-P=89
      VL1T-P=75
      VDM-P=412
      VDT-P=411
      PRIMARY=467A
      PRE-TR=-50 microA
      TR=260A
      SP=-100microA
      BAIS=600V
      SP-N2=-100microA
      TR-N2=260microA
      THANKS
      AKM
      Hi,
      it could be (FM2-9647-000) PRE-TRANSFER CORONA ASSEMBLY ( you can try to make one photocopy without the pre-transfer corona to check if it improves ).....it could be (FM2-9716-000) TRANSFER/SEPARATE CORONA ASS'Y............
      All the best
      • D_L_P
        Self Employed
        • Oct 2009
        • 1196
        Re: ir5065
        Looking at that sample I would keep your focus on the developer unit and it's drive. That the density begins fine and fades only following text/image, to me, looks as if the developer is not turning as fast as it should.
        I had the exact same issue on an ir7105. There is a developer speed setting in service mode, not sure if the ir5056 has that setting too. Try to increase speed if you can.
        How many copies are on the meter? If over a million I'd replace the developer drive clutch.
        Does the developer turn freely? You may have a bearing starting to seize up or all the gears packed with toner.
        Good luck!
        • akm
          • Sep 2012
          • 155
          Re: ir5065
          Good luck!
          Hi
          the machine makes about 1750000 i want to ask a question that the toner can cause that copy or not i will check the developer drive
          thanks
          akm
          • mramlawi
            • Jul 2011
            • 838
            Re: ir5065
            have you tried to make clear DC if you did this problem will occur try to turn back the factory value settings ,you can also try to make clear DC if you didnt do that but make sure to make p-print and after that work from the beginning
            Distinguished road makes you jewel in rough
            • copier tech
              • 8144
              Re: ir5065
              Yes I agree, I would look at the dev drive, I'd start by removing & cleaning the dev drive clutch or simply replace it.
