canon ir 3045 freqent jam
  • daddy boat
    • May 2015
    • 4
    [Jamming] canon ir 3045 freqent jam
    i am working on a canon ir 3045 which jams frequently in the fixing unit.what should i do.thanks
  • mramlawi
    • Jul 2011
    • 838
    Re: canon ir 3045 freqent jam
    tell us the jam code , check the heater sensor some time the sensor broken in the middle of it theres a small plastic check it ,the jam occur on one sided or 2 sided
    Distinguished road makes you jewel in rough
    • Brian G
      • Mar 2015
      • 21
      Check the duplex inverter guide that sits on the door, specifically the foam pads that it rests on. When they get old the guide sits too low in them and gets stuck which will keep the paper from exiting the fuser properly. Also posting the jam code does help others help you.
      • daddy boat
        • May 2015
        • 4
        thanks you very much.
        • copier tech
          • 8193
          Also if you are fitting just the fixing films, not the fixing film unit then these will cause fuser jams & smudging etc.
