Need Help Bizhub 362 ERROR
  • ck1
    • 485
    [Dead] Need Help Bizhub 362 ERROR
    Anybody have this issues ,when you on the machine screen show ERROR . i try to refreash firmware it show
    FlashRom Setuo
    ERASE ok
    Program
    ERROR: 0x0000e011
    Apr 9 2005 14.55.16
    Help thanks
    • 14355
    Re: Need Help Bizhub 362 ERROR
    99% of abort codes are related to the MFBS board. That is the place to start. Swap it with a working board and see if it boots normally. Don't forget to use the original NVRam from the machine.
    • ck1
      • 485
      Yes change the MFBS still the same . i try swap the NVram ok at the same board ( can NVram intial or repair it ?)thanks for reply
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        Does it still do it when not connected to the network ?
        I have seen this caused by as little as 1pc running the wrong driver printing to the machine.
        EDIT: Sorry, didnt read your post properly, didnt realise you were unable to load firmware.
        • John@Joplinoffice
          • Apr 2016
          • 8
          Has anyone recovered a machine with this error. Mine happened during a firmware upgrade and is now dead! Any help would be greatly appreciated. Thanks!!!
          • Synthohol
            Certified Konica Expert
            • 5735
            If im reading the manual correctly thats an OS processing error. Yoy can try to reseat the ram and the NVRAM but if that wont work then as others have pointed out you must change the mfbs and or the mfbs/2 board.
            Good luck.
            • John@Joplinoffice
              • Apr 2016
              • 8
              Hey Synthohol, what manual do you find this in. I have both NEC and Konkica Minolta versions and don't see this anywhere!?
                • 14355
                I recently had a firmware issue with one of these. It would fail when my colleague would use his windows 8.1 laptop to write the CF card. When I would write it with my windows 7 machine it would be fine. The file was a bit bigger when written with win 8.1. Couldn't figure out why.
                • Synthohol
                  • 5735
                  Right in the BH 362 service manual. Search the pdf for "abort code" it will take you right there.
                  • John@Joplinoffice
                    • Apr 2016
                    • 8
                    WOW... and I am on Win 10!!! But tried new DL on Win 7 but no go... Acts like it is stuck in the program mode. Says erase ok but program error 0x0000e011!!!
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4524
                      99% of the time abort code is caused by a corrupt print job. like someone here posted unplug the network cable if no abort code then go to each computer and delete all pending print jobs.
                      • John@Joplinoffice
                        • Apr 2016
                        • 8
                        Abort code happened during firmware upgrade... not on a network. Thanks for the reply though. John
                          • 14355
                          Take the CF card and format it on the Win 7 computer, write the firmware to it and try again
                          • John@Joplinoffice
                            • Apr 2016
                            • 8
                            Already tried that as well... Unfortunately for me, this is on an NEC IT 3640D, and from what I have been told by 2 different ex-NEC dealers, NEC made some kind of change and once it errors out during a firmware upgrade, it will not try to re-read the cf card, like the bizhub models will. The MFBS2 must be replaced! Found one at HYTEC for $1600.00!!! So that ain't happening! Got a good parts machine though!!! only 200K! LOL!!! Thanks again to all for the help!!!
                            • Synthohol
                              • 5735
                              Can you ISW via FTP?
                              Hated those stupid cf cards and just used ftp for firmware.
