Is kip 7170 same as kyocera 4820w
  • kyogenius
    • Jul 2012
    • 136
    [Misc] Is kip 7170 same as kyocera 4820w
    Have recently noticed that these models look exactly the same .is the kip 7170 same rebranded kyocera 4820w
    failure is not an option !
  • antone
    • Oct 2014
    • 344
    Re: Is kip 7170 same as kyocera 4820w
    Trouble code E801...not in manual
    Sent from my SM-N920V using Tapatalk
    • allan
      RTFM!!
      • 5462
      "Failure is not an option!"
      Its a choice.
      Whatever
      • antone
        • Oct 2014
        • 344
        Sorry E0801...toner density....not y...it came up
          • 23009
          Nope. E081 is toner density.
          I'm thinking that E801 is something to do with memory capacity. When my enduser sends 54 pages at ~1/2M each, it locks up during the first page and must be shut down to clear. The corrupt job remains in the queue until it is deleted. If my enduser sends 35 pages or less it does not occur. Maybe there's a limit to how many pages that the queue will hold?
          Does anybody have a definition of this code? It doesn't appear in my manual. The only reference I can find is "Other Service Codes not listed in the manual", and refers to three bulletins that I don't have. =^..^=
          • Woxner
            • Jul 2011
            • 851
            do you think it could be e801 transfer chrarge
              • 23009
              It seems unlikely, since it seems to hinge on how many pages or how many MB. =^..^=
              • Woxner
                • Jul 2011
                • 851
                this is a toner density error
                Wires: 1 Is the wire between Toner Density
                Sensor and PW13420 PCB connected
                properly?
                No Connect it properly.
                Density Sensor
                (PH11)
                2: Can you fix the problem if you replace
                Density Sensor?
                No Replace PW13420 with a new one
