951 blur image
  • svnnynight
    • Jun 2025
    [CQ] 951 blur image
    I got a couple service calls of 951 recently ,all had the same problem-the image was blurred in some area.I changed the drum ,the problem solved.But the problem came back after few weeks .The life of the drum is just 20k to 80k.Any suggestions about this issue ?Thank you very much!
  • Synthohol
    Certified Konica Expert
    • 5799
    Re: 951 blur image
    the LED array is likely dirty.
    • cruzin
      • May 2016
      • 5
      Re: 951 blur image
      I have been having similar issues. Any one else have anything to add?
      • allan
        RTFM!!
        • 5462
        Re: 951 blur image
        More likely some a foreign contaminant causing distortion in that case.
        If it was toner the image would be lighter in those areas.
        Giving every thing in that engine a good cleaning does magic.
        How does the mag roller look any scratches or build-ups?
        Whatever
          • 22997
          Re: 951 blur image
          Like the others have said: between the LED array and the charge grid, that pretty much resolves all quality issues. Do you have a sample of 15% halftone fill? That would tell a lot more. =^..^=
          • CompyTech
            Super Tech
            • Feb 2011
            • 706
            Re: 951 blur image
            Wanted to say that I had this problem a while back and It would come and go. I came to the conclusion that it was a combo of environment(higher humidity) and usage pattern(or lack there of). I checked all of that stuff, charge and LED etc. Ended up being just running a stabilizer in the morning would resolve it.
