Unknown firmware C368 series
  • wseyller
    • Sep 2012
    • 1129
  • B0265
    • Jan 2007
    • 718
    Re: Unknown firmware C368 series
    G00-A7 was released as countermeasure fw for the C-D011/D050 problem, if you set the machine the function ver 2.2 you need to upgrade the drivers to ver 4.x.
    • wseyller
      • Sep 2012
      • 1129
      I was under the impression that the firmware that prevents those issues was A7PU0Y0-F000-GXX-B0 which just flashes the sata controller version as I understood it and the one to recover is A7PU0Y0-F000-GXX-A8.
      I don't see an G00-A7 anywhere in base firmware or special firmware downloads.
      Also there isn't a version 4.x driver available for download. Still using the latest available version 3.1.4.0 driver. Where do you see a version 4.x driver?
      Keep in mind, I'm in the US.
      • B0265
        • Jan 2007
        • 718
        G00-A7 was a temporary solution before the release of GXX-B0. The 4.x drivers are available at the European KM site.
        • wseyller
          • Sep 2012
          • 1129
          Thanks for the info. Just strange we get a couple copiers with this firmware when this driver is not released on the US site.
          Sent from my Nexus 6P using Tapatalk
          • Copier repairman
            • Aug 2019
            • 86
            will need the following files
            You can help me.
            canonrp@naver.com
            jabattgg@gmail.com
            Recovery Tool firmware
            A7PU0Y0-F000-GXX-A8
            Preventive firmware
            A7PU0Y0-F000-GXX-B0
            USB-BOOT 펌웨어
            A7PU0Y0-F000-GG3-54
            USB-FW 펌웨어
            A7PU0Y0-F000-GC3-54
            USB-SATA 펌웨어
            A7PU0Y0-F000-GXX-A6
            • Synthohol
              Certified Konica Expert
              • 5879
              A7PU0Y0-F000-G00-X4 is the latest.
              the ones you listed are waay old.
              • Copier repairman
                • Aug 2019
                • 86
                [QUOTE = Synthohol; 1657501] A7PU0Y0-F000-G00-X4가 최신 버전입니다.
                당신이 설계 한 것들은 오래되었습니다. [/ 견적]
                Thank you.
                A7PU0Y0-F000-G00-X4
                Can you send it to me?
                  Thank you.
                  A7PU0Y0-F000-G00-X4
                  HAHAHAHA
                  you need a contributor badge https://www.copytechnet.com/forums/v....php?do=donate
                  • copier tech
                    • 8196
                    You can help me.
                    canonrp@naver.com
                    jabattgg@gmail.com
                    A7PU0Y0-F000-GXX-A8
                    Preventive firmware
                    A7PU0Y0-F000-GXX-B0
                    USB-BOOT 펌웨어
                    A7PU0Y0-F000-GG3-54
                    USB-FW 펌웨어
                    A7PU0Y0-F000-GC3-54
                    USB-SATA 펌웨어
                    A7PU0Y0-F000-GXX-A6
                    Happy to help drop us an email
                    Firmware Update - Printer & Copier Firmware
                    • Copier repairman
                      • Aug 2019
                      • 86
                      당신이 나열한 것들은 오래되었습니다. [/ QUOTE]
                      Thanks to you, I was able to get the firmware.
                      Is the GXX-B0,GXX-A8 firmware not necessary?
                      Will the G00-X4 firmware alone solve it?
                      • pangolin
                        • Jan 2022
                        • 3
                        Were you able to get a hold of the A7PU0Y0-F000-G00-X4 firmware?
                        I need this same firmware and can't find it anywhere. Our printer is broken without it, and we're a small charity organization which can't hire a professional technician. Any chance you still have the file or a link and could share it with me?
                        • femaster
                          • May 2011
                          • 1519
                          I'd suggest you start your own thread, and then tell us what the problem is. While firmware can be a wonderful thing, and is useful for fixing some pretty unusual problems, it is also rare when it is absolutely necessary to make a machine functional. I'd bet that your problem can be fixed without it.
                          • tsbservice
                            Field tech
                            • 8042
                            +1
                            • feracampos
                              • Jul 2021
                              • 40
                              Hello Synthohol, the G00-X4 is still the latest?
