Konica Minolta C280
  • mearmi
    • Oct 2010
    • 350
    Konica Minolta C280
    Getting paper jam. code is 3003
    it jams sometimes when entering Fusing Unit. And sometimes in the bridging unit at entrance.
    Please advise
    Thanks and Kind Regards,
    mearmi
  • allan
    RTFM!!
    • 5462
    Re: Konica Minolta C280
    Check the registration roller.
    It binds up and can cause that kind of jam.
    Whatever
    • wseyller
      • Sep 2012
      • 1129
      I seem to remember long ago a bulletin to replace an with an updated exit section paper guide and also a change to the fusing unit.
      Edit:
      Look at bulletin #7705. It says for 3205 jams but maybe related.
      The following changes have been made to resolve paper exit jamming issues (J32-05) when using low grade
      paper (intense paper/moisture uptake with a low rigidity).
      Sent from my Nexus 6P using Tapatalk
      • habik
        • 2013
        Check if the vertical guide isnt dislogged from hinges on Tray 1 or 2. They tend to snap on the clip. There is mod as reinforced part to keep it in place.
        Firmwares HERE
        • jonbonse
          • Jun 2009
          • 737
          Hi
          Would you have the mod part number?
          • habik
            • 2013
            Originally posted by jonbonse
            Hi
            Hope this helps:
            Tray 1
            A0ED569100 - Reinforce Part Front
            A0ED569200 - Reinforce Part Rear
            Tray2
            A0ED579100 - Reinforce Part Front
            A0ED579200 - Reinforce Part Rear
            These will help to keep the Vertical guides in the hinges, it may not cure the J30-03. Your reg flag may be weak on spring or worn.
            Replace it together with Registration sensor.
            Also check for any dust on sensor or disloged flag in the upper brach section (vertical conveyance door section on top)
            Firmwares HERE
            • Don N.
              • Nov 2011
              • 409
              [QUOTE=wseyller;521120]I seem to remember long ago a bulletin to replace an with an updated exit section paper guide and also a change to the fusing unit.
              Edit:
              Known Error
              Updated: 6/9/2015 7:40:32 PM
              Related Products:bizhub C220,bizhub C280,bizhub C360
              Jam code 3205
              Root Cause
              Jam code 3205
              with paper jammed at the Fusing Unit. This may occur when paper is fed immediately
              after warmup.
              Workaround/Fix
              CAUSE: Due to environmental high temperature and/or high humidity, paper curl is excessive and, in transport,
              paper catches the paper exit guide.
              SOLUTION: Please install the Guide Film (p/n A0ED 7414 00) and Slide Tape (p/n A0ED 8972 00) as is shown
              in attached Bulletin Number 7587.
              If the guide is damaged or worn please replace it with the modified one (p/n A0ED 8904 02). See attached
              replacement instructions.
              A modified Fusing Unit assembly (p/n A0ED R720 22) now includes the Guide Film. Please see attached Parts
              Modification Notice for the changes.
              Model Guide Film Addition (S/N) Guide Change (S/N)
              bizhub C360 A0ED011011326 and onward A0ED011012293 and onward
              bizhub C280 A0ED012009313 and onward A0ED012009980 and onward
              bizhub C220 A0ED013008095 and onward A0ED013009131 and onward
              • Hansoon
                • Sep 2007
                • 3391
                Anyone having for me please that Bulletin # 7587?
                Thanks in advance
                Hans
                • Synthohol
                  Certified Konica Expert
                  • 5863
                  7587 as requested
                  • Hansoon
                    • Sep 2007
                    • 3391
                    Thanks very much!
                    Hans
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4736
                      just a side note, those reinforce mods for the vert guides are not to repair if tab is broken off. This mod will prevent breaking easily and like the other poster said keep in place.
                      • copier tech
                        • 8190
                        The key issue here is poor quality/damp paper.
                        Try customer on thicker paper, 90/100GSM works great in high humidity environments.
                        • Don N.
                          • Nov 2011
                          • 409
                          And yet, I have a realty with about 15 agents and a school with 30 users that manage to knock them out, even with reinforce parts. I want to post a SLOW THE HELL DOWN sign on the right door!
