AirPrint on Bizhub C224 none E version
  • doinbox
    • Jan 2013
    • 120
    Is it possible to have AirPrint enabled on a C224 none E version. According to the bullitin it states it is available on C224 and also the E versions. If it is possible could someone explain what firmware I need to be on. As Far as I'm aware you upgrade to A9 then to K9 to turn the machine into an E version but I did this, changed the software switch to function 7 and when I apply the software switch for AirPrint it isn't saving. Any ideas. Thanks
  • Synthohol
    Certified Konica Expert
    • 5896
    Re: AirPrint on Bizhub C224 none E version
    there is nothing bluetooth or wireless in the 4 series.
    you need an EK-208 to enable this.
    if the copier is on the same as their wireless network with the same IP scheme just download pagescope mobile and presto!
    • doinbox
      • Jan 2013
      • 120
      AirPrint on a 224e works through a device connected to the same network nothing to do with Bluetooth or wifi adapter.
      • copyrooks
        • Oct 2013
        • 210
        It's not available with this model. If they need to print with iPhone go with pagescope mobile app.
        • doinbox
          • Jan 2013
          • 120
          No problem. Just baffled me how it mentioned both ranges on the bulletin. Thanks anyway
          • Woxner
            • Jul 2011
            • 853
            If you update the voice data to version 7 and turn a dip sw on it will show the air print if not mistaken. I just did the BH284 to do this.
            • Woxner
              • Jul 2011
              • 853
              could have been a 284e will have to check
