Bizhub 601 has acute autism...
  • Synaux
    • Mar 2012
    • 1224
    Here is why I am fooling with the Frimware:
    1) Printing to the MFP has become extraordinarily slow especially with PS drivers (used different computers, different drivers, reset all settings, manually changed the adapter speed, eliminated the network and more).
    2) When printing, the image is shifted about 1/4" down the page (toward the operator side) regardless of the tray used and it doesn't happen all the time.
    Both of these issues manifested on the same day.
    • 22960
    Re: Bizhub 601 has acute autism...
    If you can set up TCP/IP but cannot view the webpage or print I would think that your IC208 print controller is toast. =^..^=
    • Synthohol
      Certified Konica Expert
      • Mar 2016
      • 5748
      is the firmware correctly placed on the stick?
      you also need printer controller firmware G80-35, slow printing and no webpage display in browser thats where i'd start.
      you update firmware through ISW in service mode, not boot into it. not like the series of this century.
      • Create the BW75_60 or LoadableDeviceDriverROM folder directly under the USB memory route.
      • When copying the firmware to the memory, be sure to copy ".bin" file and ".sum" file or ".drv" file
      and ".sum" file at the same time.
      • Be sure to copy the files of each firmware to the USB memory in the configuration of the folders
      shown in the below.
      • In bizhub751/601, [Image_controller] folder is not used. (Composition of the folder is common
      with bizhub 750/600. )
      • If the copying is not completed correctly, a message " The data is not found" is displayed on the
      panel when the ISW files are selected.
      BW75_60
      MFP_controller
      Operation_message
      Image_controller
      Printer_controller
      Finisher_controller
      Fax_controller
      • Synaux
        • Mar 2012
        • 1224
        G80-35 is for "Machines that had replacement-processor boards installed during production can be identified by a square
        blue label next to the serial number on both the machine and the shipping carton. "
        G00-31 is for the FS-524/FS-610
        Here is the doc: 8088.pdf
        Also, I feel like a total dink...I thought it updated upon power cycle. I am writing the firmware now. Thanks!
        • Synaux
          • Mar 2012
          • 1224
          Lets hope not, but I got some more testing to do now
          *Edit* I can view page scope after I enabled DHCP
          This confuses me a little....
          PC-32 “Printer Controller Firmware” 1-19-2009
          “Printer_controller
          57aa000c0g320000.bin / 57aa000c0g320000.sum
          57ba000c0g320000.bin / 57ba000c0g320000.sum”
          Whereas MFP-20 is called “MFP Firmware” 12-13-2010
          “- Printer_controller
          57aa000c0g340000.bin / 57aa000c0g340000.sum [bizhub 751]
          57ba000c0g350000.bin / 57ba000c0g350000.sum [bizhub 601]”
          The PC-32 is in the base firmware section online, but I think should be a "special firmware" and superseded by MFP-20?
          Wrote firmware (MFP-20) and had to format HDD
          PS drivers still transfers data in 4kb chunks per second...
