BH-363, planets, PLANETS??
  • Hansoon
    • Sep 2007
    • 3389
    Got a BH-363 from a wholesaler. Instead of the Minolta Logo it is showing at starting up PLANETS!
    Machine is otherwise working fine, but I don't want no stinking planets I want my good old Minolta logo back.
    Any chance to change this please?
    Hans
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: BH-363, planets, PLANETS??
    CAUSE: Incorrect settings.
    SOLUTION: To change the Configuration Page header to Konica Minolta bizhub, please perform the following:
    1. Access the Service Mode.
    2. Select System 2.
    3. Select Software Switch Setting.
    4. Enter Switch No. "10".
    5. Bin Assignment "00000000".
    6. Hex Assignment "02".
    7. Click on Fix.
    8. Click on End.
    9. Power the MFP OFF/ON.
    10. Print another Configuration Page. Page Header should now be changed to Konica Minolta.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4723
      Yea, I've had those planets before. It is the firmware version usually on the re-branded models.
        • 23009
        I seem to recall the rocket launch, and planets on earlier models of Konica Minoltas. =^..^=
        • Hansoon
          • Sep 2007
          • 3389
          2. Select System 2.
          7. Click on Fix.
          8. Click on End.
          Worked. Thanks!
          Hans
          • copyman
            Owner / Technician
            • Sep 2005
            • 4723
            You are right blackcat, the rocket ship was from the really old Di-5510, etc.
            Most of the time I have seen the planets on NEC branded machines.
            What I have been seeing a lot lately is the customer or the dealer installing a custom logo on the startup screen.
            • Synthohol
              • 5849
              anyone remember the ants going to a picnic on the realllly old EP8010s?
              • copyman
                Owner / Technician
                • Sep 2005
                • 4723
                Don't think I ever worked on the EP8010 but remember working on the EP6000 which I think was similar, I never saw the startup screen because I was always praying with my eyes closed that the machine would come up to ready
                • Synaux
                  • Mar 2012
                  • 1224
                  I am pretty sure that the NVRAM recovery caused planets a c650 I was working on a while back.
                  • darry1322
                    • Oct 2010
                    • 817
                    Yep, I remember those guys.
                    • emujo
                      • Jun 2009
                      • 3009
                      Remember the whale surfacing with the space shuttle launching in the background? Big ass Konica..6090 or something close to that. Ants were my favorite, I think it was a NVRAM mandatory change that removed those little critters. Emujo
                      • Synthohol
                        • 5849
                        on the old EP machines you had to replace the EEPROM, there was no NVRAM back then
                        later on, the animations were removed by firmware IIRC.
                        • Hansoon
                          • Sep 2007
                          • 3389
                          Did not find a solution for this so we took out the fax card and the machine will go to another customer not needing the fax option. Have to rebuild now one again for the previous customer. Sigh......
                          Hans
                          • Hansoon
                            • Sep 2007
                            • 3389
                            2. Select System 2.
                            7. Click on Fix.
                            8. Click on End.
                            Worked. Thanks!
                            Hans
                            Well, this time same procedure with another machine but same firmware G00-D6 it didn't work strange enough. Stinking planets are still there.
                            Any ideas please?
                            Hans
                            • tsbservice
                              Field tech
                              • 8020
                              I'm not sure for this model but you can change BootUp screen to picture you like with Boot Screen Converter.
