bizhub 223, no possibility to change the reproduction size in main-scan direction?
  • Laserbeam
    • Aug 2011
    • 152
    [Misc] bizhub 223, no possibility to change the reproduction size in main-scan direction?
    Hello,
    the reproduction size in main-scan direction is not exactly as desired, when the customer prints from the PC.
    In Tech-menu I found the settings for "Printer Area" - "Paper Feed Direction Adj." but no possibility to change the value for "Main Scan Zoom Adj".. This feature is only available for the Scan Area (Copy from glass plate or Scanning).
  • Synthohol
    Certified Konica Expert
    • 5824
    Re: bizhub 223, no possibility to change the reproduction size in main-scan direction
    In the driver under advanced there is printing defaults. There should be a zoom% you can increase and save it as the default.
    This has nothing to do with copying so it wont interfere.
    • Laserbeam
      • Aug 2011
      • 152
      Thanks for your fast reply!
      In the driver (Basis Tab) I only found the Zoom %-Value from 25 to 400%. But this value changed the reproduction size in main- and sub-scan direction. I only want to change the reproduction in main-scan direction.
      Have you a screenshot?
        • 14720
        Are you sure the document you are printing is sized correctly? Maybe you can modify the width of it.
        • Synthohol
          • 5824
          is the document letter instead of A4 or vice versa? is that why it prints too small?
          what size paper and document are they trying to print? im across the great pond and we use 216x279mm (letter) im just wondering if its a conversion issue?
            • 23007
            If you go to your document's Properties, what size is specified in the electronic document? Does it match the paper you're using? If not, is Auto A4>LTR or Auto LTR>A4 being used?
            • Laserbeam
              • Aug 2011
              • 152
              The electronic document is A3 and the paper for the prints A3 too.
              The prints are absolutely correct in the paper feed direction (this value can be changed in Tech-Menu), but in Main Scan Direction they are about 2 mm too small. That is it what the customer criticizes.
              If I had the ability to change the value in Main Scan Direction (only in print mode), such as it's possible in the Copy or Scan Area, the problem would be solved.
              • Synthohol
                • 5824
                Wow 2mm? Thats nothing
                Anyway check the settings in the driver/application fir "fit to page" or "print to PDF size"
                Try them both independently and see if any change is noted.
                Is it missing part of a border that the natural edit erase is deleting?
                A sample would be nice to see.
                Print out a single halftone page from test mode in service and compare the edit erase to what he expects to see. If his documen falls outside of the edit area he is SOL.
                • kingarthur
                  • 1355
                  Try...admin settings, system settings,expert adjustment,scanner adjustment, then either horizontal or vertical..never had to do it, but it may work
                  • kingarthur
                    • 1355
                    sorry...realised it was when printing...ignore the above...it's cos you said main SCAN
