C224 reset tool
  • AG2827
    • Jul 2019
    • 9
    #31
    Re: C224 reset tool
    in the port where the FM is installed
    Originally posted by Synthohol
    where on the machine are you plugging the usb stick?
    • Synthohol
      Certified Konica Expert
      • 5847
      #32
      Re: C224 reset tool
      So just to be clear you are using the hidden usb behind the metal slider plate you need a screwdriver for?
      • AG2827
        • Jul 2019
        • 9
        #33
        Re: C224 reset tool
        yes, on that side or port I am putting my usb but it does not read it, also try in the port that is behind the control panel and it does not recognize it ... what suggestion can you give me to restart the Service Mode
        • bogdanchr
          • Jul 2019
          • 4
          #34
          Re: C224 reset tool
          Try another USB drive!
          • bogdanchr
            • Jul 2019
            • 4
            #35
            Re: C224 reset tool
            thx mate
            posting how to enter service mode in a public forum is not wise.. we dont even know if this is a tech or end user..
            suggest relaying that info via PM
            • Synthohol
              • 5847
              #36
              Re: C224 reset tool
              Turn copier off hold down panel reset turn Copier on when it prompts you enter 9272 4x it end now you're in service mode
              Also the usb stick has to be 4gig or less and you have to take all the files out of the firmware folder and put them on the root of the usb drive.
              Should have:
              App
              Bin
              Fw
              IPtables
              Satafw
              Work_fw
              And about 40 0ther bin files.
              That is what belongs on the root of a 4 series firmware.
              The 8 series and up you just need the fw000x folder on the root.
              Usb must also be formatted fat32 not fat or ntfs or ex-fat.
              You won't need service mode to install firmware..
              If you are using the reset file that's all that needs to be on the root of the usb.
              4 gig drive or smaller.
              • AG2827
                • Jul 2019
                • 9
                #37
                Re: C224 reset tool
                thanks I am going to change usb because I was using a 2gb I have another but it is 8gb and the .tar file that I have when I extract it only appears 1 dstore
                Should have:
                App
                Bin
                Fw
                IPtables
                Satafw
                Work_fw
