C224 reset tool
  • Elmo
    • Feb 2010
    • 541
    C224 reset tool
    Hi All
    I have a used C224 just come in with the CE Password changed from default
    i have tryed all the different combinations i know but it looks like i will have to reset the machine
    is there a reset tool for the C224
    i have it for the E versions
    I Used To Live To Fix Things Now i Fix Things To Live
  • mx6turbo89
    • Oct 2013
    • 154
    Re: C224 reset tool
    Are you referring to the MFPB reset tool? If so, the Color 'e' and Color non 'e' tool is the same.
    • Woxner
      • Jul 2011
      • 850
      Re: C224 reset tool
      92729272 instead of try 9272927292729272 or even 9272 once i have seen alot of techs set this that way
      • rrrohan
        • Sep 2011
        • 1977
        Re: C224 reset tool
        You need to get a code and supply it to km who will give you a unlock code
        This will reset the CE password
        What ive done in past is dodgy but works
        Open side door and unplug fuser
        Enter service mode password screen
        Close side door and wait for error
        Press menu
        You should now have skipped the password screen and be in
        You will have to do this each time you neef service mode
        • Elmo
          • Feb 2010
          • 541
          Re: C224 reset tool
          Thank you for the advice
          i have tried all combos of the default password
          had a go with unplugging the fuser but still asks for password
          i will try the reset tool
          • rrrohan
            • Sep 2011
            • 1977
            Re: C224 reset tool
            its possible firmware patched that. last time i tried it was on a not e model
            ill try again in office if i get it to work ill record the process for u
            ive never used the reset tool. in past ive had to enter service mode then do a stop sequence of numbers that brings up a reset screen. you then quoted the code to KM who would supply the reset code. once you input the reset code it sets it to factory default
            the code is only valid for 24 hours tho
            • Elmo
              • Feb 2010
              • 541
              Re: C224 reset tool
              if i can get into service mode you can go into enhanced mode an reset the ce password
              • rrrohan
                • Sep 2011
                • 1977
                Re: C224 reset tool
                nah because it asks for the password again before it lets you reset it
                • Elmo
                  • Feb 2010
                  • 541
                  Re: C224 reset tool
                  This is what makes buying in used machines so much fun lol
                  • Elmo
                    • Feb 2010
                    • 541
                    Re: C224 reset tool
                    can anyone recommend a usb stick brand to use on C224 i normaly use a scndisk cruzer 2g but they dont seem to like it
                    • Synthohol
                      Certified Konica Expert
                      • 5846
                      Re: C224 reset tool
                      are you plugged into the correct service port?
                      is the stick formatted fat32?
                      • Elmo
                        • Feb 2010
                        • 541
                        Re: C224 reset tool
                        Yes and Yes thought there was only 1 service port (remove the screw and lift the flap)
                        is there any other routines like leave the door open in service manual it states close door within 3 seconds of switching on
                        have noticed when doing movie data this memory stick is not always recognised
                        will get a new usb and try again
                        • Synthohol
                          • 5846
                          Re: C224 reset tool
                          Movie data gets installed through the front ctl panel usb not the service port
                          • Elmo
                            • Feb 2010
                            • 541
                            Re: C224 reset tool
                            All sorted
                            was just the usb stick it didnt like
                            Got a new usb stick 1g
                            ran reset tool as per bulletin
                            password now reset to default
                            • rrrohan
                              • Sep 2011
                              • 1977
                              Re: C224 reset tool
                              Fat32? It cant use USB3 but if its only 2GB im guessings it USB2
                              Sent from my SM-G900I using Tapatalk
