C224 reset tool
  • rrrohan
    • Sep 2011
    • 1977
    #16
    Re: C224 reset tool
    Is that tool only for c224 and not c224e. KM tech support never mentioned a reset tool when i gad trouble
    Sent from my SM-G900I using Tapatalk
    • Elmo
      • Feb 2010
      • 541
      #17
      Re: C224 reset tool
      its the same tool for all colour
      I Used To Live To Fix Things Now i Fix Things To Live
      • rrrohan
        • Sep 2011
        • 1977
        #18
        Re: C224 reset tool
        I guess benifit of KMs actual pass reset is its much easier
        • AG2827
          • Jul 2019
          • 9
          #19
          Re: C224 reset tool
          Hola fijate que tengo el mismo problema, tengo bloqueado EL SERVICE MODE, pero tambien tengo un CE04, pero no tengo el reset tool para reiniciar... tu tienes este software?? que me puedas apoyar, es que tengo 2 meses intentando con esta maqina pero tenia otros errores y no puedo sacar el codigo Token para que KM me de el otro codigo para reiniciarla.
          Espero tu ayuda
            Re: C224 reset tool
            Espero tu ayuda
            ok grave robber...
            1) thread has been dead for a few years
            2) please don't be rude... post your comments in english
            • AG2827
              • Jul 2019
              • 9
              #21
              Re: C224 reset tool
              but can you help me?
              • Synthohol
                Certified Konica Expert
                • 5798
                #22
                Re: C224 reset tool
                Please post your question in english.
                  Re: C224 reset tool
                  we will try but if you don't post in ENGLISH... I won't even try to help.
                  • AG2827
                    • Jul 2019
                    • 9
                    #24
                    Re: C224 reset tool
                    I have several problems with the 224e
                    1) CE004
                    2) I have Locked the Service Mode
                    3) I try to update the Firmware but I do not recognize the usb ... it says:
                    External memory information This function is not available
                    I already localize how to remove the CE004, but I can not enter the SM
                    I need to know how to unlock the SM and try with 92729272/001001/00000000/22222222 / none works I see a code to restart as the image but when I enter KM license I ask for token code, and as you know I have everything blocked and I can not remove it.
                    • Synthohol
                      • 5798
                      #25
                      Re: C224 reset tool
                      none of those are the SM password.
                      • bogdanchr
                        • Jul 2019
                        • 4
                        #26
                        Re: C224 reset tool
                        1)The default password is 927292792729272.try to acces service mode by starting the machine holding the yellow(reset) button for 10-15 seconds -> then press stop+00+stop+01 -> insert the 9272.. password
                        2)format fat32 usb drive
                        3)watch this video YouTube
                        4)reset tool A145FW.TAR Dropbox - A145FW.TAR - Simplify your life
                        1) CE004
                        How can you help me...[ATTACH=CONFIG]43128[/ATTACH]
                          Re: C224 reset tool
                          posting how to enter service mode in a public forum is not wise.. we dont even know if this is a tech or end user..
                          suggest relaying that info via PM
                          • AG2827
                            • Jul 2019
                            • 9
                            #28
                            Re: C224 reset tool
                            Hello friend, thank you for your interest but I am a new technician and I am working KM now and if you read my post I wrote the steps and attempts that I made to reestablish the SM.
                            So if you have other contributions are welcome
                            • AG2827
                              • Jul 2019
                              • 9
                              #29
                              Re: C224 reset tool
                              Thanks for your help but unfortunately I do not read the .tar file only the external memory message appears-Function not available and also already enter the password that you wrote to me and it does not work for that reason in the image you can see that it asks for a code .. .that I can not extract from the print either. I do not know what else to do...
                              • Synthohol
                                • 5798
                                #30
                                Re: C224 reset tool
                                where on the machine are you plugging the usb stick?
