Fiery IC-413 Dead
  • Ismael
    • May 2016
    • 8
    [Dead] Fiery IC-413 Dead
  • mrwho
    Major Asshole!
    • 4299
    Re: Fiery IC-413 Dead
    Can you ping? And what about Remote Desktop?
    Mascan42
    Ibid
    • Ismael
      • May 2016
      • 8
      What addres to ping? I connect fiery to Laptop.
      • mrwho
        Major Asshole!
        • 4299
        Ping the Fiery's ip address. Try to access it via Remote Desktop.
        If you can do those things, it could help understand what went wrong. The Fiery could be hung up on some corrupt print job - running a cleanup.bat file (somewhere on the spool folder, I can't recall exactly) might bring it up to life.
        If you can't ping or rdp to it, then there's only one thing to do: Reinstall the system firmware, with the possibility that the harddrive needs to be replaced too...
        Mascan42
        Ibid
        • Synthohol
          Certified Konica Expert
          • 5857
          with an E1 message (usually AA if SS corrupt) i would remove the cover and check the fans and heatsink on the CPU, ive seen 2 break legs and cause the fiery to error and eventually reboot. not that this one is but id check it out physically first.
          • Ismael
            • May 2016
            • 8
            Hi guys, the problem is solved. Just a deep cleaning of internal contacts, dust and lint out, and the fiery is back to life.
            Thank you
