C227 restrict copying
  • kingarthur
    • 1383
    on the old 3340 you used to be able to restrict the amount of copies possible, i.e. no more than 99 or 999, we've got a C227 going in with a fax to replace a c220, on the c220 quite often the operator would enter the fax number in as the amount of copies, and walk away with their original, the machine would only stop when the trays had run out of paper, so the customer has asked if i can set it, so they can't enter more than 99 on the copy function....anyone done this in the current range...
    Cheers
  • Woxner
    • Jul 2011
    • 852
    Re: C227 restrict copying
    well if they are trying to enter a fax # they cant possibly be entering the whole # in the copy screen..... so they are complete idiots. it cant be that they are that stupid to realize they have not selected the fax/scan tab. if they do that on the 227 if will start making copies. surely they know its not faxing.
    • mo0651
      • 1054
      OOOOOOhhhhh Woxner, Yes !! they can be that stupid. I have witnessed it! And yes it is the machines fault!
      • emujo
        • Jun 2009
        • 3009
        Software switch 49 00=unlimited, 01-09 and 0A limit from 1 copy to 250 copy max. Emujo
        • allan
          RTFM!!
          • 5462
          Hehe
          That helps a little.
          Whatever
          • allan
            RTFM!!
            • 5462
            Ran out off breath.
            hwhw
            Whatever
            • Synthohol
              Certified Konica Expert
              • 5879
              HA!
              make the fax/scan screen the default instead?
              • MVPunisher
                • 209
                3340 and a C227 being compared. That's a first ha..
                • kingarthur
                  • 1383
                  Unfortunately, the operators are that stupid , i know...comparing a 3340 to a C227, it was the last time I could remember having to restrict the usage
                  Thanks emujo...will give that a try
