Bizhub C284 Login Error when authentication and account track are turned OFF
  • captainrva
    • Oct 2014
    • 100
    I have a peculiar problem that I have never run across. A customer has 20 computers and they are all the exact same. Only 1 of those computers is now having an issue printing. The jobs are deleted due to error, and the error is a login error. I checked and both Authentication and Account track are turned off so this shouldn't be happening. I have reinstalled the driver and restarted both the computer and the copier to no avail. Any help is much appreciated.
  • copier tech
    • 8131
    Re: Bizhub C284 Login Error when authentication and account track are turned OFF
    If the issue is only happening on 1 pc out of 20 it clearly is an issue with that one PC. Most likely a currupt driver even tho you reinstalled it the pc could still be using the currupt one. It could simply be the driver setting have authentication etc enabled. Also try a different version ie PCL5/5. Also run windows update on that one PC.
    I'd also update the copier firmware.
      • 22999
      It's also possible that there is a connection issue with the specific PC. Go to that PC and start a continuous ping to the server. You might notice very long ping times, or completely dropping out periodically. =^..^=
      • Synthohol
        Certified Konica Expert
        • 5807
        wait... please explain what a log-in error has to do with printing.
        log-in is for PSWC not printing. al logon error is for scanning AFAIK.
        can you be more elabritive?
        • allan
          RTFM!!
          • 5462
          When he checks the print history on the machine it states print job "deleted due to error" detail "login error".
          As if print user authentication is failing.
          Got no clue as to why that will happen.
          I would check things like the driver printer configuration to see if authentication or account track is manually switched on. Still makes no sense.
          Or under admin i would look to see if "Print without authentication" option is available.
          Had corrupt drivers do weird stuff before.
          The suggestion to use a generic PCL driver is good but you loose functionality.
          Would ip filtering show as an error in the printer log??
          Whatever
          • Synthohol
            • 5807
            ok, thanks for the clarification.
            yeah i'd delete the drivers and start over on that PC.
            not just the queue, the drivers too in>>>
            • Mr Spock
              Vulcan Inventor of Death
              • Aug 2006
              • 2064
              I had a wonderful IT staff that turned on the account track to monitor the print usage. Hard coded the driver so the end user would not see the popup. After some fall out with management they went back and turned account track off. They could not understand why no one could print.... The local print drivers (where they hard coded the code) was still trying to pass login info to the machine and machine was showing login error. They had to enable account track on the local pc then remove the account info then turn it off to get everyone printing again.
              • captainrva
                • Oct 2014
                • 100
                I got it sorted today. I turned authentication on and print without authentication at the panel, sent a print and it came through so I then turned off the authentication and now it prints normally. I appreciate all the help!
                • KM7155
                  • Aug 2008
                  • 145
                  Guys, i have a c364e, it cant print when the account track is enable, it showed Login Error at the details of the deleted job.
                  without the account track, no issue with the printing.
                  i did the verify password, it succeeded.
                  the firmware is A5C10Y0-F000-G20-M1(00).
                  thanks.
                  • KM7155
                    • Aug 2008
                    • 145
                    thanks.
                    what i have done,
                    reformat the hard disk
                    clear the account track entries
                    reload the printer driver
                    try new and old version driver
                    try different PC to print.
                    • pappyvonsillypants
                      • Feb 2013
                      • 30
                      thanks.
                      what i have done,
                      I am having the same issue my self. they had a c360 w account track and had no problems. we upgraded them to a c454e and with out account track it works.... with it it gives me a log in error... any resolution to this??
                        • 29973
                        thanks.
                        what i have done,
                        Are you printing to the Fiery or the C284?
                        • paulrid
                          • Nov 2011
                          • 206
                          thanks.
                          what i have done,
                          did you update the driver? Old one will do basic printing but won't work with account track due to different signing?
                            • Feb 2013
                            • 30
                            yes i had updated the driver to the new one. firmware is up to date as well... i m having their i.t. delete everything from server and pcs to start fresh in 10 minuetes i will update with any info. no fiery using empron controller.
                            • B0265
                              • Jan 2007
                              • 718
                              Make sure the correct model is selected in the configure tab of the driver.
