FS-533 First page of stapled set does not align with rest of sheets
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    First time I've experienced this on one of these.
    Guide number 7 on the stapler unit develops a nick in it from normal usage which catches only the fist sheet and stops it going all the way back into the stapler. All sheets after it go over the top of it to the back no problems.
    Good news is that it works without it just fine. Remove it and problem solved.
    This is what the nick looks like:
    • 23008
    Re: FS-533 First page of stapled set does not align with rest of sheets
    Good catch. =^..^=
    • Synthohol
      Certified Konica Expert
      • 5841
      Wow, i had a similar one today. the exit mylar on a 1052 finisher. there was a doubled up black mylar on the upper exit "feed me Seymour" gate.
      had a nice split in it and caused intermittent 7217 jams.
      nice info KM, i see that once in a while.
        • 23008
        Does it look like this?:
        • Synthohol
          • 5841
          EXACTLY like that
            • 23008
            Originally posted by Synthohol
            EXACTLY like that
            Nope. Never seen it. =^..^=
            • JOHNR
              • Jan 2021
              • 9
              [QUOTE=EarthKmTech;538794]First time I've experienced this on one of these.
              I have the same problem,even when i am not using staple the first page does not align and has an angle about half the times.I thought maybe some glue from the packaging of the paper had stuck on the rollers so i cleaned them but with no result.From the pictures you posted i cannot understand where that guide is to remove it.Can it be seen externally?I must remove entirely the finisher to access it?Maybe a zoom out picture of where it is would help me.Thanks in advance
