bizhub c554 scan/fax button is disabled!
  • eli
    Not a technician
    • Oct 2014
    • 40
    Just picked up a used machine. When I press the scan/fax button, the machine just beeps and nothing happens. Anything scan/fax related is missing from the menu.
    Is there a way to reset all settings? How can I enable scanning? Can't find any info online!
  • Woxner
    • Jul 2011
    • 851
    Re: bizhub c554 scan/fax button is disabled!
    is the hdd still in it or turned on. someone could also have turn that off in admin
      • 23009
      ... or wiped it at the termination of a lease. Do you get the message "Animation guide is not available... "? =^..^=
      • emujo
        • Jun 2009
        • 3009
        Like the way you think, but if "animation guide not available" is displaying, HDD must be installed. Emujo
        • eli
          Not a technician
          • Oct 2014
          • 40
          Nothing about animations. Hard drive is installed. No issues printing, copying, stapling, folding.
            • 14815
            Maybe this is a stupid question, but when you say hdd is installed, do you mean installed in service mode? Just being physically there doesn't mean it is "installed'
            • eli
              Not a technician
              • Oct 2014
              • 40
              Says SSD is installed, not sure if it is same as HDD. I tried researching this but I'm not a technician so my knowledge is limited.
              (btw when this pic was taken, I was printing a 4000 page document)
              • Albonline
                • Sep 2008
                • 1151
                [ATTACH=CONFIG]34845[/ATTACH]
                then the hdd is either turned off or missing, should list either a 250gig or 320gig hdd.must be enabled to scan .
                • eli
                  Not a technician
                  • Oct 2014
                  • 40
                  My apologies, I searched online and couldn't find any info. Where is it supposed to be and how do I put one in?
