Sudden vibration in Biz Hub C452
  • rogimon
    • Nov 2016
    • 10
    Hello all. This is my first post and hopefully I can get some assistance.
    I sat down to print tonight and about 5 minutes after I turned on the printer, a loud vibration began in the top of the printer ie. in the section that you lift up to put the paper on the glass for copying. The specific area the vibration is occurring is to the left all the way to the end where four white rollers are. It sounds like a jack hammer. Does anyone know what is causing this? It doesn't stop me from printing.
  • allan
    RTFM!!
    • 5462
    Re: Sudden vibration in Biz Hub C452
    Try to post an audio clip.
    Whatever
    • Woxner
      • Jul 2011
      • 840
      my guess is you toner collection pipes are clogged.
      • rogimon
        • Nov 2016
        • 10
        Please see short clip attached.
        • mx6turbo89
          • Oct 2013
          • 154
          That's quite a horrendous noise from an ADF. Sounds a bit like a guide plate is bent and scraping against one of the driven roller shafts.
            • 22999
            I had a Kyocera making a worse sound than that once. They had been scanning documents that had been mailed to them that had some of the sticky silicone goop on the flap. Quite a lot of that sticky stuff got adhered to the idlers just before the white plate, and two of those idlers would not turn. It was not a simple disassembly, but simple to diagnose. The sound clip does help, thanks. =^..^=
            • allan
              RTFM!!
              • 5462
              Why would the rollers be running?
              Noting i know about will make a noise like that and not code out.
              As if something cant get to home position.
              Whatever
              • copier tech
                • 8132
                That is a series issue, does it make the noise if you're not printing?
                • rogimon
                  • Nov 2016
                  • 10
                  99% of what I do is printing I don't remember the last time I copied anything. So I am surprised that the noise is coming from that area. Any suggestions as to how I can fix it? Do I need to pull it apart? Do I need a technician?
                  • rogimon
                    • Nov 2016
                    • 10
                    The noise begins about 20 seconds after the machine is turned on and has completed its "booting" phase - for lack of a better word.
                    • habik
                      • 2013
                      Check if the retraction motion isn't somehow looped. Its driven by the front M4 motor behind the near side front cover. There is a cam mechanism. Never seen it doing this, but you never know until you ope it up. Be brave take a screwdriver and just open it like a box of chocolates on X mas.
                      or
                      loosen belt on drive transport rollers and its sliping on drive gears
                      or
                      you have somthing gunged up on the read transprt roller and is doing what you see.
                      Firmwares HERE
                        • 14522
                        If you don't use this machine to make many copies, just unplug the DF. Turn off machine, unplug from the wall and disconnect DF from main body. You still use the glass for copying.
                        • mascan42
                          • Oct 2008
                          • 481
                          How long does the noise continue for? I would think it should only try to run for a few seconds before giving up, and then give an error code.
                          • rogimon
                            • Nov 2016
                            • 10
                            Apologies for my absence. When the noise starts, I put the machine in Power Save mode and it stops. However, today I did that, left the machine for an hour, and when I returned and took it out of Power Save mode, I got a C8101 error. There is also a message which says I can continue if I disable the automatic document feeder. When I press continue, it says to "turn the sub power switch off and on". Is that the main power switch? I'm not sure.
                            Edit: Found the switch. The DF is now disabled. No more noise.
                              • 22999
                              C8101: Before reading pressure welding alienation mechanism
                              This code means that the reading roller pressure/retraction motor (M4) in the document feeder is not rotating at the correct time. There might be a problem with the read roller sensor (PS6), or the DF controller.
                              If you wanted the document feeder to work, I would suspect the DF controller board, which controls that motor.
                              If you don't care if the DF works, it is currently isolated and won't bother you again.
