FUN WITH NUETRAL/GROUND!!!
  • mo0651
    • 1054
    Hey Gang!! Does anybody use any kind of a surge protection device that knocks down the neutral to ground? We have always had good luck with ESP Z models, but they have quit making them. We are looking for a replacement! Would like to hear some thoughts!
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: FUN WITH NUETRAL/GROUND!!!
    honestly anything over half a volt i tell the customer to call an electrician.
    • Albonline
      • Sep 2008
      • 1151
      We use nextgen,work good under most circumstances.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        It is a customer responsibilty to provide proper power.
        Yes, we sell some power protection, but we can't be expected to be the do-all, end-all, be-all solution.
        I know we all have power nightmares to share, so here's my worst one:
        A Canon NP 350 in a factory office kept blowing a motor controller board.
        After the 3rd one in about 3 months, it finally dawned on me *DUH* to check the wall voltage.
        About 120 volts between hot and neutral, but 384 volts (no typo) from neutral to ground.
        It was a wonder nobody got shocked (or worse). Even more unbelievable the machine actually worked.
