Konica Minolta Bizhub C454e Print/Scan
  • mearmi
    • Oct 2010
    • 346
    [Misc] Konica Minolta Bizhub C454e Print/Scan
    Konica c454e stopped Scanning/Printing. Ethernet connector light is ON.IP settings are correct and is not pinging Please adviseThanks
  • Woxner
    • Jul 2011
    • 839
    Re: Konica Minolta Bizhub C454e Print/Scan
    use a laptop to see if it connect. use a cross over cable you can also try a network reset. possible mfp is bad
      • 22997
      It may also help to hard set the network communication speed (rather than Auto). =^..^=
      • emujo
        • Jun 2009
        • 3009
        A minor or major network change could cause this issue. NIC would show connection LEDs, but configuration no longer matches the network so you would lose communication. Could be a gateway issue, or did you move to a different ISP. Emujo
        • Rvale
          • 83
          i had the same situation today, checked verything without success, my check list for such situations goes like: Config page print, ping, connect with crossover, Cable, sockets, router, Initialize, firmware, PRT Board, OACB.
          But you have to check it all yourself, dont rely on anyone to clear some points for you.
          Rgds.
          • mearmi
            • Oct 2010
            • 346
            It is pinging and printing
            we didn't change ISP
            client reset the settings and got this issue
            • Woxner
              • Jul 2011
              • 839
              what is the scan error? is this email smb or ftp
              • rrrohan
                • Sep 2011
                • 1977
                The fact he mentions ISP obviously means he used email.
                It could even be server fault. Mailbox full?
