Konica Minolta C652 - Too much magenta
  • jeid
    • Jan 2017
    • 5
    [CQ] Konica Minolta C652 - Too much magenta
    Hello,
    I've got an issue with a KM C652 producing too much magenta on prints/copies/internal prints. A new Magenta imaging unit has been fitted and calibrated up, which fixes the problem short term, but within a week, the issue returns. When I returned to the machine and did a halftone print (value set to 100) magenta came out looking as if it were set to 255. Full bold magenta. The other colours were fine. Cyan and Yellow imaging units were replaced in August. The Transfer Belt/Roller are expected to run until the end of 2017.
    I did some samples of before and after I changed the magenta IU, which was fine, but it's gone back this way again. Any ideas on something I might be missing?
  • Tech Helpdesk
    • Jul 2015
    • 112
    Re: Konica Minolta C652 - Too much magenta
    If there is a magenta cast over the entire page, replace the yellow IU, I have had this problem before on a C451 when the yellow IU was dragging down the bias on the magenta.
    Originally posted by jeid
    Hello,
    [ATTACH=CONFIG]35221[/ATTACH]
    • jeid
      • Jan 2017
      • 5
      I went in and had another look. The customer said that the run started off fine then had more of a magenta hue as the run went on. The differences are very noticeable.
      The obvious thing that I'm thinking is towards the magenta unit, but yeah, yellow could be a shout actually.
        • 22937
        Are you using OEM toner? =^..^=
        • jeid
          • Jan 2017
          • 5
          Aye, all OM toner etc. Replaced all colour IU's now and I've got a laser unit coming tomorrow.
          • allan
            RTFM!!
            • 5459
            Check your TCR levels on M?
            Whatever
            • jeid
              • Jan 2017
              • 5
              Checked that as well, all looking good. New magenta toner installed as well, it's a bit of an odd one.
              • Woxner
                • Jul 2011
                • 829
                do the reset and inalization then gradation
                • jeid
                  • Jan 2017
                  • 5
                  Done that too. Several times.
                  • KM7155
                    • Aug 2008
                    • 145
                    Hi
                    have u solved the issue?
                    my problem was cyan cast over entire paper.
                    any help really appreciated.
